Oil pump gears play | FerrariChat
Oil pump gears play
Discussion in '456/550/575' started by plip, Nov 28, 2020.
  1. plip
    plip Formula Junior
    Aug 25, 2003
    292
    Switzerland
    Gianni Olivieri
    Hi
    in an attempt to locate a rattling noise coming from the front of my 575, have started by removing the sump cover and the oil pump. Whilst the oil pump shaft bearing looks OK at the first glance, am not sure the oil pump is. When holding the scavenging gears with my finger, and try to rotate the shaft there is quite some play before the scavenging gears engage (see attached video). Wonder if this normal or if this could be the source of the rattling noise?
    Many Tks
    Gianni
