Oil pump, Oil Routing Questions | FerrariChat
Discussion in '206/246' started by utah4re, May 10, 2017.
  1. utah4re
    utah4re Karting
    Nov 1, 2005
    52
    Does oil from the pump go first to the heat exchanger, then to the oil filter, before going to the engine rotating parts, cams, cylinders, crank then to the oil pan. Which port on the filter mounting assembly does the oil go out to the heat exchanger (top or bottom). It seems like a poor design having the oil filter inverted, any thoughts?
  2. Dino Club Germany
    Dino Club Germany Formula Junior
    Nov 10, 2008
    549
    Germany
    N. Schumacher
    #2 Dino Club Germany, May 10, 2017
    It goes first from the oil pump to the oil/water heat exchanger, then to the filter , crankshaft, camshafts ... see picture.
    "poor Design" was optimized over lifetime: As it takes too long till the oil from the sump arrives at the cams (causing worn out cams after low mileage) , Ferrari made several modifications:
    a) on the cams itself with different grooves for better oil distribution
    b) with inner tube in the filter which eliminates it´s draining after engine stop.
    This allowed to bring the oil from the filter quicker to the cams as before from the sump.
    Regards Nicolai
  3. utah4re
    utah4re Karting
    Nov 1, 2005
    52
    Thankyou, I was afraid that was the case.
  4. racerboy9
    racerboy9 F1 Rookie
    2,645
    From that graphic, it seems if you wanted to prime an engine for first time start you could pour oil down the top heat exchanger oil hose, re-attach and spin it over with the plugs out.
