Oil radiator - replacement advice needed please | FerrariChat
Discussion in '348/355' started by Gottaloveit, Aug 20, 2013.
  1. Gottaloveit
    Gottaloveit Karting
    Jul 12, 2012
    52
    Hi guys
    Sad to say my 355 has developed a small leak in its oil radiator (bottom r h corner). My query is twofold really - is this a non repairable item (the construction seems different to a coolant rad) or can it be resurrected.
    And secondly - removal :do the oil and coolant rads come out as 1 ? - any tips gratefully received.
    Cheers guys -
  2. sws4re
    sws4re Formula Junior
    Jan 28, 2006
    281
    Olathe Ks
    Scott Sweat
    Not sure on repairabilty but it is pretty easy to swap out. It is a seperate unit from the radiator. Remove the wheel, wheel house, fan, oil lines, then the 4 bolts around the outside and you should be good to go. I may have missed some thing as its been a while since Ive done it but its pretty straight foward.
