430 - Oil reservoir cap help | FerrariChat
430 Oil reservoir cap help
Discussion in '360/430' started by colorfull, Dec 19, 2023.
  1. colorfull
    colorfull Formula 3
    2,340
    Franklin Park, New Jersey
    John Napoli
    So after seeing @boba fett post about his oil cap, I went on a search and found one. The person i got it from said it was from a 458, but dealer said it'll work on an F430.
    So, it does 'work', dipstick is the right length and it seats properly on the neck.
    However!
    The notches on the 458 I'm guessing are 90d from the F430, the cavallino sits sideways on the reservoir.
    I tried like heck to loosen the stem to see if I could rotate it but can't break it loose (tried both)
    Does anyone know if this is supposed to come loose? Tried PB Breaker, next I guess I'd try heat but don't want to damage anything.
    Any insight is greatly appreciated!
  2. boba fett
    boba fett Formula 3
    1,123
    England UK
  3. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    If anyone has a 458 and would be so kind as to take a picture of the notch layout, greatly appreciated, will definitely help! Thank you
    This is the F430
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    If it fits the neck, then just heat the dip stick and turn it 90 degree
  5. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,621
    San Jose
    dc
    Guessing the "spin" on the 458 is reversed? Can you get a flare wrench that fits the bottom part and try a breaker bar while cap is wrapped in towel and held with vise? Try and heat up that part with a torch or would it melt the seals?
  6. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    Thank you, I was looking for the orientation in the car.
    You gave me an idea though, went to the engine diagrams, same layout in the 458 as the F430
    So looks like the cavallino was mounted 90d rotated. Ugh
    Any suggestions how to rotate it?
    Thanks all
  7. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    Thanks gents, the more I'm at it, appears the top cavallino was not applied properly, it is otherwise same as the F430 one
    Considering heat to the top to remove and reapply the cavallino circle/badge
    Sj_engr likes this.
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,947
    Central NJ
    Dominick
    I would remove washer first and see what you are dealing with
  9. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    Washer?
    If you mean the stem/stalk, that was my plan, but it is really stubborn
    Will go next level, just don't want to damage it
  10. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    Didn't get you at first, think I see what you're saying now, just heat the bas of the stalk and rotate it
    K, guess I gotta get this thing loose
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,947
    Central NJ
    Dominick
    I mean the gasket inside the top cap .. remove that and see what is underneath it
  12. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    Oh, that's loose and just sits there to make a seal, I removed it, nothing there
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Thinking about it, I may have misunderstood your problem
  14. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    The plot thickens....
    Ok, so with some leverage, I got it apart, looks like they used maximum threadlocker on it.
    I have to rotate the base inside the cap 90d
    It's not moving
    I assume it's screwed down on top, then the cavallino cap applied
    Tried 250d heat, I know it prob gets hotter than that during normal driving, anyway that didn't loosen the cavallino at all, trying not to damage it
    Any suggestions appreciated!
  15. AandSC
    AandSC Formula Junior
    957
    Jax, FL
    Allen
    The Cavallino on top appears to be pressed in. Not sure it can be removed without damaging the cap though. Have you tried spinning the Cavallino on top, maybe by tapping a part of the horse right at the raised part? The bottom part looks like it’s meant to be in the current position.
  16. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    Hi Allen
    Thanks for the response.
    I believe you are correct in that the bottom part is where it's intended to be based on the original cap and pic at the top of this thread.
    I did try and move the cavallino as you describe, no luck. I think it was just built incorrectly.
    I am assuming maybe they assemble the base, then press the cavallino on with some double sided tape, was hoping I could lift it, but not looking likely.
    Rats
  17. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,621
    San Jose
    dc
    Place in oven?
  18. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    Maybe, no issue getting it hot, I'm just not sure if my assumption is correct. I really have no idea how the cavallino gets on there and if it's cemented on, its probably not coming off.
  19. cpep
    cpep Formula Junior
    438
    new york
    CHARLIE
    The one I have is the same. It doesn't sit right but I was unable to to adjust it so I left it alone. Still look's better than the stock one.
    colorfull likes this.
  20. AandSC
    957
    Jax, FL
    Allen
    I figured that would be the case, but I had to throw my thoughts out there.
  21. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    Thanks Allen and everyone's support, it's a little thing, but it's great to get other's perspectives when trying to figure out what the options are.
    Appreciate the support of this community for all things, big and small!
    LorenzoR and AandSC like this.
  22. AandSC
    957
    Jax, FL
    Allen
    Okay John, after much thought, and because I want to help you solve this, I figured out a solution.
    Remove the oil reservoir, take it to a local machine shop and have them remove the top of the reservoir and replace it at a 90 degree rotation, weld it back up, repowdercoat and reinstall the reservoir. Problem solved.
    :D
  23. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    LOL
    Theoretically, I could make notches on the other side, but I'm not.
    AandSC likes this.
