Oil Seal Install on Crankshaft (timing belt side) | FerrariChat
Discussion in 'Technical Q&A' started by vincenzo, Mar 29, 2008.
  1. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    #1 vincenzo, Mar 29, 2008
    eulk328 - This is a new thread since the title you used was specific to the back side of the crank. Thought a new thread would make the 'timing belt side' info easier to find with the search engine.
    Anyway...
    This 1-1/2"x2" reducer works great to press the seal into place on the front side if the crank. The pic shows the crank nose bolt & washer of a TR in place. The 1-1/2" black pipe is cut to length to allow the crank bolt to be used as a press.
    The black pipe combo creaked a bit, but did not fracture. Use safety glasses with this one! Works great - pushes the seal in place nice & straight.
    Wound up using greased business cards on the seal to keep everything in place as it pressed in as suggested by carguy here:
    Rgds,
    Vince
  2. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Good stuff!
  3. DANCER308
    DANCER308 Formula Junior
    Oct 24, 2009
    935
    KY
    Dan
    #3 DANCER308, Dec 12, 2010
  4. SRobertMaser
    SRobertMaser Rookie
    46
    someone repossessed
    my 550
  5. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    PVC is our friend!
