Oil selection for Ferrari Mondial 3.2/328 | FerrariChat
Discussion in 'Mondial' started by JoeZaff, Sep 23, 2008.
  1. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    I am getting ready to do a 1000 mile service for my '86 Mondial 3.2. My mechanic is recommending a 20w/50 weight oil. Ferrari of NA recently changed their recommendation from the Shell Ultra Helix to the Quaker state Q 5w/40.
    I am thinking the 20w/50 may be too thick, especially in a car with so few miles (16K). However, I am nervous that the synthetic oil may end up leaking through the seals, as it did when I switched to a synthetic oil on an older Audi 90 Quattro sport some years back. My mondi is currently loaded with castrol 10w/30.
    Just to be clear. I am looking for the oil that will best preserve the life of the engine...not the one that will increase my HP.
    Also, my driving consists of mostly 30-70 mile spirited country drives. She takes very few long trips. I do plan on driving her until the roads get salted and then garaging her until Spring.
    I have reviewed the prior posts, and gotten some insight. However, any new suggestions would be appreciated.
  2. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    I recently had my 328's oil changed while I was having a state inspection done. These guys - http://www.rmccar.com/whoweare.html - did a separate overall inspection of the car and changed the oil. They use Mobil1 15W50 for the Ferraris though they will use whatever oil you want.
    Though you mentioned it is not an issue, in the early 80's we did dyno tests that showed a 5-6HP increase using Mobil one over conventional oils of the same weight in a 440CID engine at 7000 RPM. SO why not take advantage of a slight HP increase over conventional oils in addition to the other advantages of syn oil?
    Admittedly, the advantages are probably not really worthwhile if you are changing oil every 1000 miles! Just as a side note, Porsche factory fill is Mobil 1 and the recommended oil change intervals are 15,000 miles...
  3. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    I know I sound off my rocker on the oil changes, but this is my first Ferrari and I am trying to go by the book on all the services and then some. I figured while I had her in for the 1500 mile service (admittedly early), I would do the oil too.
  4. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    I have used synthetics in my 328 for many years with no leakage problems. Later years of 328's and I presume Mondials, Ferrari changed the recommendation to 10-40 oils. There were no changes in the motors but oils have gotten much better. I use Mobil 1 0-40. It flows much better at startup which is critical and retains viscosity at high temps (which you never reach in street use anyway) about as well as 50 weights.
    Dave
  5. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    #5 350HPMondial, Sep 23, 2008
    WalMart,
    Two gallons of Mobile 1
    15W-50
    Edwardo
    (I have a 1992 Chevy 4 X 4, , , 289,000 mi.
    18 MPG,
    No leak oil,
    No burn oil,
    ....Mobile 1, 10W-30)
  6. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    I would either go with Ferrari and use the Q 5w40 or if you really want to take care of your engine go online and get Motul 5w 40.
    dave
  7. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    Why the strong recommendation for Motul. What experience do you have with it?
  8. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,557
    NY/SC
    David
    #8 ducowti, Sep 23, 2008
    While not Ferrari, or even a car, my Ducatis do NOT get Motul based on what a nationally renowned Duc wrench's shop reported after tearing down engines using various oils including of course Motul. I don't recall what the issues were but the message was clear: Motul not recommended. Oil opinions are like arssholes though right? That said, it's my belief that if a brand did relatively poorly in one machine it stands to reason it may perform similarly in another.
    Take the 'book' w.a grain of salt though Joe; there are often political angles to a manufacturer's recommendation. E.G. Ducati says 'use only Shell oil' right on the oil case :rolleyes: Shell is/was a major sponsor at that time. I've been using only M1 in my Ducs for tens of thousands of miles and my engines are in great shape. I can't imagine our Fs are too different.
    I think your biggest concern should be which weight to use, and that of course may vary depending on seasonal climate changes.
  9. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    We use Motul based on the recommendation of our Ferrari mechanics. They are highly respected and consider Motul to be the only choice based on their research and experience. Basically I trust these guys, but how would I really know if Motul is better? I guess that if my motor doesn't blow up it must be good :)
    dave
  10. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    Agreed. I am not as concerned with the brand as the weight and synthetic vs nonsynthetic. FWIW, I can't see Quakerstate being any better than my trusted Mobile 1 or Castrol
    To te
  11. F1 MONZA
    F1 MONZA Formula Junior
    Sep 6, 2004
    483
    California
    I USE TOTAL QUARTS OIL. I bought from POLEPOSITION
    WEIGHT IS 10-50 .....SPECS ON THE OIL IS AS FOLLOWS....TOTAL LUBRIFIANTS
    16, rue de la République
    92800 PUTEAUX
    QUARTZ RACING 10W-50
    Synthetic multigrade oil for Gasoline and Diesel engines
    SPEC ON THE OIL ........
    QUARTS RACING OIL 10-50
    1. 15.C UNITS KG/M3 856
    2. VISCOSITY @ 40.C MM2/S 115
    3. VISCOSITY @ 100 .C 17.0
    4.VISCOSITY INDEX 164
    5. FLASH POINT 240.C
    6 POUR POINT -45 .C
  12. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Brand? I use the most popular oil that has the least number of complaints or questions and that is why I primarily use Castrol. The first time I start hearing complaints about it I will move to the next most popular. I have nothing personal for or against any of them, Castrol included, only what I hear from others. I just really dont care about the manufacture, I care about my engine. Mobil? No way in hell. Far too many complaints, questions and people with oil leaks. I wont use any oil that has a bunch of questions, its just not worth the risk IMHO. And I dont care if YOU never had trouble, the fact that others have are what pushes me away.
    Viscosity? I have my own opinion. I have read the operating requirements of hundreds of engine powered machines, from airplane engines to heavy diesel equipment, motorcycles to lawnmowers, cars to trucks. Virtually every single stationary or industrial gas and diesel engine manufacture, regardless of displacement, call for 50 and 60 weight oils when ambiant tempertures rise above 90F, even engine manufactures like Ford, Honda and General Motors. It is only those manufactures automobile engines where they suggest lower viscosity oils, and its all based on US government EPA CAFE standards. The telling part is when you see power equipment that use common auto engines. The same engine that was in a car and told to use 5W30, in power equipment is required to run 50 weight at high operating temps. And this is direct from the engine manufacturer. Same crankshaft, same engine bearings, same oil clearances, its just not in a car.
    All the engine manufactures cant be wrong, and all the weekend warrior car owners cant be right. The manufactures are the ones who have to warrantee their stuff, and they are the ones who see oil related engine damage first hand. And unlike car makers, they also want to protect thier good name. If Cummins, John Deere, Caterpillar, Mack or Case started blowing engines, if Honda started blowing up thier motorcycles or lawnmowers, they would lose customers. I dont care how great a warrantee is, contractors buy heavy equipment to do a job not sit in a shop getting a new engine. And they dont pull oil viscosity figures out of thier a$$.
