Oil smell on startup | FerrariChat
Discussion in '612/599' started by Motorama, Aug 27, 2018.
  1. Motorama
    Motorama Karting
    Jul 10, 2018
    157
    Stijn Van Loffelt
    Anyone Else Experencing an Oil smell on startup Untill The engine is warm on a 599
  2. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,785
    Weston, MA
    Paul
    Sounds like you have some seepage that then burns off.
  3. Motorama
    Motorama Karting
    Jul 10, 2018
    157
    Stijn Van Loffelt
    I've never seen any oil under the car.. must be dripping on the exhaust somewhere then..
  4. Motorama
    Motorama Karting
    Jul 10, 2018
    157
    Stijn Van Loffelt
    neither did I see smoke
  5. jstar
    jstar Karting
    103
    up north
    jstar
    I noticed this as well.. thought it might have been due to armor selling the engine cover..
  6. Skidkid
    Skidkid F1 Veteran
    9,523
    Campbell, CA
    John Zornes
    Likely that your oil is overfilled, and you are smelling oil blowback into the intake. Look at the oil level check procedure. It is very fiddly but critical for the 599. You even want to run it a bit low. The blowby will ruin the MAFs as well.
    George Vosburgh likes this.
  7. bryanchin
    bryanchin Karting
    Jul 7, 2016
    82
    Malaysia
    Bryan Chin
    i had the same issue... got oil seepage... leaked out of the cam cover gaskets... got it replaced and all is well
    Skidkid likes this.
  8. Autodetailing
    Autodetailing Karting
    Oct 5, 2021
    220
    This happened on my 599, small rubber hose at the rear of the engine for the blow back system had split, but i had smell plus smoke on start up until it had burnt off.
