Oil Sump Cover Gasket: Dry or w/ a Sealer?? | FerrariChat
Discussion in '308/328' started by Dr Kananga, Jun 9, 2017.
  1. Dr Kananga
    Dr Kananga Formula 3
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    I've seen both discussed here.
    I've seen both being successful.
    I used Hondabond before and seemed to not leak but if I can put it on dry... that would make things much easier as I am having a hard time working the sump cover back on (yes, the dipstick tube is out).
    Thanks all.
  2. Dr Kananga
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    I am DEF going to go with a sealant.
    I used Threebond 1184 before.
    Seems to be fine.
    Has there been any preferred gasket updates in the last few years?
    Thanks all!!
  3. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    I like Permatex Ultra Black. Great for sealing oil.
  4. Dr Kananga
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
  5. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    There's your answer. Hondabond is great stuff and it worked for you before. Why change?
  6. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Klingersil gasket dry. No leaks. Prepared squeaky clean.
  7. Dr Kananga
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    I remember it being a "thing" to buy since I had to source the international Threebond and I don't even recall how I even did that.
  8. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,809
    Cerritos, CA.
    Four years ago when I changed my shift shaft seal, I've used the Threebond for the pan gasket and until now it hasn't leak a drop, and that's using synthetic oil too. I know Hondabond is good too.
  9. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,326
    Montana
    Kim
    Another vote for Hondabond.
