Oil Sump Cover Installation: The Secret Sauce?? | FerrariChat
Discussion in '308/328' started by Dr Kananga, Jun 9, 2017.
  1. Dr Kananga
    Dr Kananga Formula 3
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    What is the trick to get this thing back on?
    I'm trying to dry fit it so I can get a "feel" for it before I get in there with gaskets that have sealant on them (unless you convince me to go dry --> http://www.ferrarichat.com/forum/308-328-sponsored-yellow-compass-group/553993-oil-sump-cover-gasket-dry-w-sealer.html).
    I got it in once.
    No clue what happened... just kinda happened.
    Every time I get in there, it seems like it will never pass over the oil pickup tube.
    ... and I don't want to damage the pickup tube cause, I'm sure, that is a nightmare.
    What's the secret sauce, guys?!
    Thanks all.
  2. BigTex
    79,386
    Houston, Texas
    Bubba
    Remove the dip stick tube, certainly
  3. Dr Kananga
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    The cover would not have come off if that wasn't out.
    But I got it going.
    Required me to find my balls and get 'er done.
    Getting around that oil pickup pipe is a bit unnerving but it happens.
  4. Pero
    Pero Formula Junior
    825
    Sweden
    Peter R
    From what I remember it is "tilted" in place. Not straight in. I think the front part of it goes in a bit earlier and the rear part follows just behind. Sorry, no pics to show and intermittent memory.
    /Peter
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    I took the studs out but left the dip tube in place, the sump pan will drop down just enough to clean off the old joint. You then have to tease the joint into place and replace the studs on a dry joint. Worked on my mondial 3.2 ok. Taking the dip tube out is fine but i understand it is a pig to get it back in again.
  6. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    The secret is to tilt it much further than you think it should be tilted.
