Oil sump cover | FerrariChat
Oil sump cover
Discussion in '308/328' started by F308fan, Jun 24, 2022.
  1. F308fan
    F308fan Karting
    May 7, 2017
    163
    Peoria, AZ
    Tony Pacini
    Seeking used engine oil sump cover for 1981 308 GTSi (US version) in good condition. Mine was repaired before I got the car and is now leaking. I may have to try to repair it (again) as a last resort, but if I can round up a decent used one I’d prefer to go that route instead.
  2. 4right
    4right F1 Rookie
    Is the leak coming from the cover or the drain?
  3. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    It looks like they glued it??
    I suspect a competent welder could fix it well enough not to leak. Maybe retap the drain if needed.
  4. F308fan
    F308fan Karting
    May 7, 2017
    163
    Peoria, AZ
    Tony Pacini
    The drop was hanging from the drain plug, so the cover may be cracked at the hole. Yes, it was repaired with some type of hard sealer. Not welded.
  5. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    I have an 83’ one
  6. F308fan
    F308fan Karting
    May 7, 2017
    163
    Peoria, AZ
    Tony Pacini
    That’s my backup plan if I can’t find another cover; scrape the repair material off and have the cover welded and re-tapped.
  7. F308fan
    F308fan Karting
    May 7, 2017
    163
    Peoria, AZ
    Tony Pacini
    It appears to be a different part number for the QV engine sump cover, not sure what the difference is or if it could be made to fit.
  8. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I know your pan is a mess, but be aware that every oil leak on the engine works its way down to the oil pan to look like a pan leak even when it's not. You might want to be sure that it's really the pan that's leaking, but I admit that I'd be looking for a replacement just based on how it looks even if it's solid.
  9. F308fan
    F308fan Karting
    May 7, 2017
    163
    Peoria, AZ
    Tony Pacini
    I agree with you on all counts. I drove it, put it in the air, sprayed it off, and the drain plug was the first area to show signs of leakage again.
  10. miked
    miked Formula Junior
    Feb 7, 2001
    898
    Cincinnati, Ohio
    That's a "repair" ????
    I'd call it well past a hack, more like an abuse.
    If it were mine I would media blast the "sealer" off and see whats underneath. Depending on your skills and tools it may be feasible to fix if you can't find a replacement at a reasonable cost. A good welder should be able to weld up any cracks. A new oversize drain plug can be fitted after a drill and tap.
  11. F308fan
    F308fan Karting
    May 7, 2017
    163
    Peoria, AZ
    Tony Pacini
    Update: it wasn’t a cracked sump plate after all. Despite how ugly that repair is, that’s not where it was leaking. I drained the oil, cleaned and inspected the threaded area in the sump plate, and could find nothing wrong. I couldn’t feel or see a crack nor was the threaded insert out of place. I’d read somewhere on this forum that the standard-type copper drain plug gasket often requires over-tightening to seal (if at all), and I’d been using copper. I installed an aluminum drain plug gasket and now the leak is gone.
  12. pappy.72
    pappy.72 Formula Junior
    Nov 13, 2010
    536
    Elgin, IL
    Dave
    Remember, crush washers are supposed to be a one time use item. When it comes time to change the aluminum one replace it and don’t reuse it. I might be stating the obvious but some might not know.
  13. F308fan
    F308fan Karting
    May 7, 2017
    163
    Peoria, AZ
    Tony Pacini
    Dave,
    It was a new copper crush washer and it leaked anyway. Maybe it was too hard, maybe the top and bottom weren’t parallel enough, who knows? I’ve ordered more aluminum ones and I’ll use a new one at every change.
  14. conan
    conan Formula Junior
    Nov 13, 2011
    389
    I noticed an earlier repair done to my 328 oil drain plug. Unfortunately, the thread was not straight 90 degrees to the seat of the plug. It can be checked by some marker pen and tightening slitghtly. Then have a look where the seating is uneven. Sand down the high spots until flat.
    The other problem can be the crush washer, but you can easily anneal it with a torch and polish the surfaces of the washer until flat. Sandpaper in circular motion only.
    No need to overtighten anything. It will seal if the seating is right.
    Skickat från min SM-A320FL via Tapatalk
  15. Ehamilton
    Ehamilton F1 Rookie
    2,643
    Durham, NC; USA
    Eric Hamilton
    I tracked my leak at the drain plug down to a nick in the sealing surface on the outside of the pan. The standard size crush washer was too narrow to cover the entire nick, but Belmetric had one with the same ID and and 2mm greater OD - bought a dozen, use a new one at every oil change, problem gone.
