355 - Oil Tank removal - any advice ? | FerrariChat
355 Oil Tank removal - any advice ?
Discussion in '348/355' started by Gottaloveit, Oct 8, 2019.
  1. Gottaloveit
    Gottaloveit Karting
    Jul 12, 2012
    52
    As part of this winter's work, I want to get the oil tank powder coated - anybody got any good tips on removal or is it as straight forward as it looks ?. ( this is a Ferrari of course it's not !!!!).
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Buy all new seals and gaskets and washers when done and be carful to not strip any bolt holes.
  3. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
    Forget the gaskets until you get the dam thing out first :D
    Take out the wheel fender liner to be able to get at the middle bolts that holds the tank. Of course when you have removed the hoses and disconnected the sender wire from under the tank. Be sure to use protective tape on everything around the tank including the subframe tubes and cam cover. Remember the tank has a peg at the bottom that sits in a rubber Bush. Good luck with trying to get that bugger out :D
    You will see the reason why most re coat the tank while the engine out for a major. It's a bugger.
    taz355 and Qavion like this.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,577
    San Carlos, CA
    Mitchell Le
    And this is why you should do it with the engine out service....
  5. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    Thank you mr obvious
  6. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    552
    Tempe
    Jon
    Be sure to have the correct wrenches for the oil lines. Depending on the last mechanic, they could be over tight and you do not want to rip/distort the aluminum.
    Be patient trying to take the tank out with engine in the car.
  7. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    Dont do it because you will go crazy and f it up. Do it when the engine is out. Why powder coat? Use black wrinkle paint like what's on there now or should be on there.
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    I concur it sounds like many of us you want to make it perfect so just go enjoy it until the service then like many of us spend a long time during the service on all the little things
