Oil tank to pump feed hose #179338 | FerrariChat
Discussion in '360/430' started by 348TN, Mar 6, 2023.
  1. 348TN
    348TN Karting
    Oct 14, 2020
    93
    Chattanooga TN
    Full Name
    Surprised not to find any posts about this part, 360 F1 short hose from the F1 reservoir tank to the pump. Looks to be part# 179338. I’m
    curious if any substitutes exist, seemingly benign simple hose priced at $200. I’m guessing not giving the lack of info anywhere.
    Hose #21 on the diagram here
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    £54 from superperformance in uk
    348TN likes this.
  3. Ricambi America
    Sponsor Owner
    We sell about 30-35 of those per year. It is not an 'uncommon' item to replace. It's a molded/formed hose, not a 'user twisted' kind of rubber thing. And If I'm not mistaken, the two ends have different diameters.
    E60 M5 and 348TN like this.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,562
    San Carlos, CA
    Mitchell Le
    Buy it. Don't try to make it, it won't end well. There is a Ferrari tax but it is not something that is found outside the offical channel. It has two different ends, two 90 degree turns, is oil resistant, and you cannot substitute it with a generic hose.
  5. 348TN
    348TN Karting
    Oct 14, 2020
    93
    Chattanooga TN
    Full Name
    It looks like my reservoir tank is seeping slightly at the seams ... that could be the source of the fluid I'm seeing at the hose connection point actually. (though, I know how these things go ... it's most likely leaking at both).
  6. yelcab
    Nov 29, 2001
    13,562
    San Carlos, CA
    Mitchell Le
    That reservoir is cheap. Just change it out. Buy a BMW unit.
    348TN likes this.
  7. 348TN
    348TN Karting
    Oct 14, 2020
    93
    Chattanooga TN
    Full Name
    Thanks, I'll look for the BMW part number (unless you / someone knows already).
    Related, does anyone know of a non-OEM accumulator bottle that works for a 360? (OEM part# Accumulator Bottle 58552368 or 247346)
  8. yelcab
    Nov 29, 2001
    13,562
    San Carlos, CA
    Mitchell Le
    32411097164 is the BMW part number. ALthough, if you search for E30 BMW power steering reservoir, there are a number of less expensive non-BMW parts.
    348TN likes this.
  9. 348TN
    348TN Karting
    Oct 14, 2020
    93
    Chattanooga TN
    Full Name
  10. yelcab
    Nov 29, 2001
    13,562
    San Carlos, CA
    Mitchell Le
    I would not go that far. The "bomb" is likely rated to a different maxium psi.
    348TN likes this.
  11. AandSC
    AandSC Formula Junior
    957
    Jax, FL
    Allen
  12. 24000rpm
    24000rpm F1 Rookie
    its $10 here I made in a shop.
