Oil temp gauge does not work on my 1990 348 | FerrariChat
Discussion in '348/355' started by Mera, May 28, 2007.
  1. Mera
    Mera Formula Junior
    Aug 13, 2005
    768
    Milwaukee, WI
    Rodney Dickman
    Anyone know where the sensor is? If I can get to it easy I should be able to ground the wire and the gauge should go all the way to the right? That would at least tell me if it is the sensor - correct?
    Rodney
    1990 348 TS
  2. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    Nowhere important, USA
    #2 rivee, May 28, 2007
  3. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Yes, the oil temperature sensor is on the bottom of the oil tank, and it is rather "famous" for the gauge to malfunction due to a weak ground for the tank. It is recommended that a ground wire be installed running from one of the studs/nuts on the bottom plate to the frame.
