Oil temp on track day? | FerrariChat
Discussion in '348/355' started by plugzit, May 31, 2006.
  1. plugzit
    plugzit F1 Veteran
    7,775
    Redondo Beach, CA
    Bruce Bogart
    What does your oil temp run after a few laps? Mine was getting up to about 250-do I need to check the oil cooling system, or is that about what yours runs? I'm running the motor in the 5-7.5k range.
  2. jjstecher
    jjstecher Formula Junior
    Jan 21, 2002
    962
    Rochester Minnesota
    John Stecher
    Mine runs in the 240-260 range when in the 80 degree air temperature.
  3. plugzit
    plugzit F1 Veteran
    7,775
    Redondo Beach, CA
    Bruce Bogart
    Thanks, John!
    PS: Put some Yokohama A048s on. Reeealllll sticky!
  4. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    Sounds normal. Use synthetics!
    -Peter (seen as much as 270-280 and, after oil analysis, am convinced I'm ok...)
