OIL TEMP RAN HI WHEN REV UP HIGH | FerrariChat
Discussion in 'Technical Q&A' started by ferrame, Mar 23, 2005.
  1. ferrame
    ferrame Formula 3
    Mar 2, 2005
    1,196
    Orange, Calif
    I have an early 95 f355b that oil temp run hi up to 275 degrees when run on high rpm. The coolant temp is normal. I can start the engine and let it idles for hours, the oil temp would not get hot. It stays at about 190-200 degrees. But when I start driving about 5 to 10 miles @ rev up to 8000 rpm,
    the oil gets hot. I checked and removed all oil lines and also checked the fan there is nothing clogs and the fan is working properly.
    Does anyone have any solution to this problem.? By the way, it has less than 20k miles and all services had been performed.
  2. f355spider
    f355spider F1 World Champ
    18,055
    I believe the 355 has a thermostat in the oil lines to the oil cooler. Yours may be stuck closed....so no oil is going to the oil cooler.
  3. ferrame
    ferrame Formula 3
    Mar 2, 2005
    1,196
    Orange, Calif
    Thank you! Hugh I will try that
  4. TOM B
    TOM B Formula 3
    Jul 24, 2003
    1,038
    Orange County, NY
    Thomas Buckley
    Dave,
    When are you going to tell him that this isn't your name.....merely wishful thinking on your part? ;)
    Tom
    I couldn't resist.
  5. Jdubbya
    Jdubbya The $10 Trillion Man
    43,692
    Hell's waiting room
    Right after Craven Moorehead admits that's not his real name!!
  6. TOM B
    TOM B Formula 3
    Jul 24, 2003
    1,038
    Orange County, NY
    Thomas Buckley
    You mean that's NOT his real name !?!?
    Tom
