430 - OIL TEMP SENDING UNIT 2007 | FerrariChat
430 OIL TEMP SENDING UNIT 2007
Discussion in '360/430' started by Steelton Keith, Aug 25, 2025 at 11:24 AM.
  1. Steelton Keith
    Steelton Keith F1 Veteran
    7,828
    Raleigh NC
    Keith Hall
    Went through the manual and can't find diagram of where this is. Also searched this thread. Oil temp gauge not registering. I had fluids changed a month ago and thinking something jarred sending unit? But first, where is it and is this something I can fix or troubleshoot? Thanks
  2. LorenzoR
    LorenzoR F1 Rookie
    pretty sure its under the intake towards the rear of the car. You can see it just by looking down in
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,999
    Central NJ
    Dominick
    right next to motor oil screen access
    Steelton Keith likes this.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,999
    Central NJ
    Dominick
    That's the pressure sensor
  5. Steelton Keith
    7,828
    Raleigh NC
    Keith Hall
    still can't find it after looking at several miniscule diagrams
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,999
    Central NJ
    Dominick
  7. LorenzoR
    LorenzoR F1 Rookie
    Dom i am seeing brake calipers
  8. Steelton Keith
    7,828
    Raleigh NC
    Keith Hall
    I guess I should ask if I do locate the sensor is it the kind of thing a guy with no skills and no tools can check/inspect/replace or is it a mechanic's job? Thanks everyone. Keith
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,999
    Central NJ
    Dominick
    I apologize I did post the same picture as Lorenzo but for some reason I don't know where it got that calipers from
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,999
    Central NJ
    Dominick
    Yes
    Yes
  11. Steelton Keith
    7,828
    Raleigh NC
    Keith Hall
    OK. so service manager says sensor is inside lower oil pan!
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,999
    Central NJ
    Dominick
    Keith it is very easy to get to ...locate the motor oil screen go to the side of the sump and up 1 in
