Oil temp spike on 360 | FerrariChat
Discussion in '360/430' started by Breakup, Jun 27, 2014.
  1. Breakup
    Breakup Rookie
    Apr 18, 2013
    24
    So I have been searching the forum trying to find some answers, but it has been all over the board.
    This past weekend, I was driving around town (city driving), and noticed all of the sudden my oil temp went from normal (just on first line of guage) to tapping the red with a light flash, then falling back to halfway point on guage. Based on my findings, it is more than likely a bad sensor? With that said, would it be safe to drive 5-10 miles to buddies house to get worked on? If it were bearing, which I also heard makes oil temp hot would it spike like that as warning?
    Thanks in advanced.
  2. Evan.Fiorentino
    Evan.Fiorentino F1 Rookie
    Aug 23, 2005
    2,854
    South East Florida
    Evan
    Sounds to me like a bad sensor as well. Tough to see why else it would spike quickly and drop right off.
  3. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    It's almost certainly a sensor as they are known to go bad. I would doubt it would suddenly go from normal to max and back again. If in fact the oil was getting hot -- it would creep up slowly. Also your water temperature would also get really hot.
    Alan
  4. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,449
    On the Limit
    Dino
    Sensor, and a short drive is fine.
  5. 993turbo
    993turbo Formula Junior
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    Bad sensor, Instrument (less likely) or connection issue (shorts to ground).
    No issue to drive anywhere, but smart to get it fixed. :D
  6. Breakup
    Breakup Rookie
    Apr 18, 2013
    24
    Awesome! Thanks guys. Just wanted a little confirmation prior to driving it a short distance.
    I was told it was part# 104628 and I could order it from Ricambi for $18... does that sound right?
    Thanks.
  7. Chiaroman
    Chiaroman Formula 3
    1,687
    New Jersey
    I have similar issue with my oil pressure gauge.
    Most of the time it is perfect, then fluctuates a bit.
    Will have the sensor replaced at the next fluid annual.
  8. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    #8 English Rebel, Jun 27, 2014
    I believe it's item #89 part# 104628 $19.54 but someone confirm that as it says it's in the gearbox but listed under oil pump and sump category. I think the engine oil somehow is located in a compartment in the transmission because when they replaced my rear main oil seal they had to drain the engine oil.
    Alan
  9. vrsurgeon
    vrsurgeon F1 World Champ
    16,527
    Charleston, SC
    Curt
    Alan is correct above. The oil flows to the disaereator above down to the bottom of the diff housing where this sensor is located. Jus tbe careful when you take it out that you drain the oil beforehand! :)
  10. Breakup
    Breakup Rookie
    Apr 18, 2013
    24
    Thanks for the responses! Yes, I've seen that diagram on another thread. I just ordered the part, planning on just doing full change at same time. I let you know how it goes.
  11. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Curt
    I would like to know why engine oil ends up in the differential? Is it because there is a separate container in there as my mechanic had to drain the engine oil completely to pull the transmission to replace the rear main oil seal? I guess they had to have a place for the oil to drain to because if it drained to the oil pan it would flood the crank on start up.
    Alan
