Oil temp | FerrariChat
Oil temp
Discussion in '360/430' started by drcripp, Jan 12, 2017.
  1. drcripp
    drcripp Karting
    Nov 1, 2016
    123
    Pittsburgh
    David Crippen
    Normally, I start my 360 up and let it idle for one minute, following which I just start driving it normally (keeping it under 4000 till the water temperature bumps). I saw a video the other day in which a guy in his 360 remarked that he doesn't start driving the car until the water temp bumps and keeps it under 4000 till the oil temp bumps.
    Is that realistic?
  2. boostd
    boostd Karting
    May 4, 2014
    68
    I stay under 4000 until the oil temp is around 170*. Takes a while for this when it's cold.
  3. raider1968
    raider1968 F1 Rookie
    Mar 13, 2008
    4,966
    NC Mnts & Asheville
    John E
    Yes
  4. Rifledriver
    37,105
    No. That is why they invented multi grade oils. With 5-40 oil driving with cold oil is a non event.
  5. Rifledriver
    37,105
    On some of the cars the oil temp needle never moves on a cold day. And by cold I am talking about 40 something degrees, not freezing.
    If we had to wait for perfect oil temps we could only drive the cars a few months a year. Way too much paranoia about this.
  6. vrsurgeon
    vrsurgeon F1 World Champ
    16,543
    Charleston, SC
    Curt
    I agree but I'm not revving my 360 above 4000 (maybe 4500 rpm) until the oil temp moves to the first line on the oil gauge regardless of oil grade. I don't do higher RPMs in my 997 either until oil temp has warmed. I want that oil film to be as effective as possible especially in the later half of the year as engine by products accumulate in it.
  7. Rifledriver
    37,105
    I guess I have to park Testarossa for half the year then. A part of the year the oil temp never moves. I must have already blown it up and just don't know it.
  8. tazandjan
    39,176
    Daytonas are the same way. Drove mine from Houston to Clovis, NM (~800 miles) and actually thought the oil temperature gauge was busted. Finally, as I got near Lubbock, the gauge came up to 60 C, so I knew it was not kaput. 16-17 quarts of oil keep pretty cool at moderate (70-85 mph) speeds.
    Funny thing is, my 575M does not show that same thing. Oil temperature comes up to 160 F in a few miles, even on a 30 F day.
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,945
    Central NJ
    Dominick
    I did research ..Alot of it in 2001 and I distinctly remember that you really should wait until oil gets to 175 before beating any engine .....Normally a 5 mile drive driving briskly keeping engine lower than 3500 but moving at highway speed accomplishes this...The best is to drive around town at 35 40 for 5 miles or so going thru gears before getting on her
    Sent from my Moto G (4) using Tapatalk
  10. Rifledriver
    37,105
    575 has a thermostat, Daytona does not. TR has a very large cooler and no thermostat. At idle for a very long time and it will creep off the bottom but go any steady speed and it looks like it is broken.
  11. Rifledriver
    37,105
    It's best but as Terry and I have pointed out there are some models that will never happen in and neither have ever suffered for it. In fact, the TR even with keeping the oil too cold is known to be one of the longest lasting motors Ferrari has ever built.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,945
    Central NJ
    Dominick
    Gotcha 👍👍
  13. RedNeck
    RedNeck F1 World Champ
    12,328
    The CSA
    Me
    I can probably guess the video. He posts here sometimes. No its not necessary to let it idle before driving, but that makes for a boring youtube video about why you can't drive it every day.
  14. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,515
    Honolulu
    Kevin
    I do this. Even in my normally warm environment it can take 15 minutes of driving before I get to the first line! It can take another 15 easy to get where I start using the whole car! I don't rev at all and stay below 4K, i feel like I am exercising discpline. Of course what Brian makes sense but I wont change my habits. I use that time to practice my gated shifter driving skills and see how smooth and efficient I can be with the clutch!
  15. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    I idle my 430 for a minute max, mostly just to let the idle settle down. Then drive under 4500rpm and within 2 miles the oil temp has hit the first mark and it's good to go. I think the handbook says something similar. Warming the oil can't hurt but I think Brian is on the money too.
  16. RedNeck
    12,328
    The CSA
    Me
    You obviously know nothing about Ferraris :D
  17. vrsurgeon
    16,543
    Charleston, SC
    Curt
    Veglia. Faulty gauge or sender unit. Clearly. :)
  18. boostd
    boostd Karting
    May 4, 2014
    68
    You mean the 120* line?
  19. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    My first mark (first line on gauge up from rest) is 60degC which is 140F for you. Full temp is 80ish degC or 180F.
  20. Zanny1
    Zanny1 Formula 3
    1,137
    Arizona
    Last time I had the 360 out it was 32 degrees here. Under normal driving conditions, oil temp never got above 160 deg F and water temp never exceeded 170 deg F.
    I always wait until the oil temp needle moves before going above 4000 RPM and don't hammer the car until the temps above are reached. Even driven hard on a cold day won't get either temp reading to exceed 190.
  21. howl
    howl Formula Junior
    Apr 10, 2011
    505
    Chicago/Boca
    Tom
    A couple of points:
    - believe F430 owners manual says to keep it under 4000 until oil warms up (need to check it but that is what I remember)
    - I don't think the issue is blowing up the engine. I think it is one of premature wear. As engine warms, different parts heat up at different speeds meaning they expand at different speeds. So think cylinder wall as it is part of a large block will warm more slowly than a light weight piston for example. I excessive revs while wall is colder (read smaller) and piston larger leads to wear. While this sounds logical to me, I a, neither a mechanic or engineer so I may be all wrong here (so do not assume this is fact). This is just what my understanding has been FWIW.
