Oil temperature on a 308GT4 | FerrariChat
Discussion in '308/328' started by Jeremy.Jennings, Jul 27, 2005.
  1. Jeremy.Jennings
    Jul 27, 2005
    9
    Brussels, Belgium
    Jeremy Jennings
    I hope this is an easy one. At a steady 80mph my GT4 water temperature is a steady 90 degrees. But oil temp is closer to 120 degrees which seems on the high side given we're only doing 4000rpm. When pottering around town the oil temp is 100 degrees. Would a new oil cooler solve the problem?
  2. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    I would find out if your temp gauge is accurate before you go and buy a new oil cooler.Then I would have the original one cleaned out.Try thes things first before heading for the deep end
  3. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    Hi
    If 120 is vertical on the gauge, then it would be fine (but at high end) IMO.
    According to what I read in the Oil threads, the type and viscosity of oil you use will reflect in oil temperature. Ditto if water temp is high, oil temp will also be high. Specifically, your water temp can be higher than what the meter shows due to air pockets. In essence the oil is used to help cool the engine, hence the oil cooler. Also check for blockages in the air flow to the cooler. Over time debris (leaves?) can collect inside the oil cooler housing.
    On my car the water temp will drop fairly quickly when speed increases (e.g. after sitting in traffic) but the oil tmep takes longer to drop.
    Regards,
    Gerrit
    http://dino308gt4.com
  4. f355spider
    f355spider F1 World Champ
    18,045
    I started reading unusually high oil temps (78 308 GTS), (water stayed normal) similar to what you are seeing. I replaced the Veglia oil temp sender ($14) and it started reading more normally (95 to 100 C). Remember, the car is plain old, and stuff fails....for so cheap a part, I would just replace it, rather than spend a bunch of diagnostic time/work. If it doesn't fix it, THEN go through the drill.
  5. Jeremy.Jennings
    Jul 27, 2005
    9
    Brussels, Belgium
    Jeremy Jennings
    Thanks, guys. I'll replace the oil pressure and temperature senders first, then see where I stand.
  6. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    #6 Ferrari_tech, Jul 28, 2005
    As well as mentioned above make sure that the lever on the air conveyor is in the right position - it's marked "summer" and "winter"
  7. thecarreaper
    thecarreaper F1 World Champ
    18,071
    Savannah
    you know until that was recently posted, i had no idea that was even there......... wow!
