Oil temperature sensor installation question | FerrariChat
Discussion in '308/328' started by Spitfire, Apr 1, 2008.
  1. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    As you probably know, the oil temperature sensor doesn't screw in so far that it butts up against a gasket of any kind. So, when you install one of these, do you tend to put a little bit of white teflon tape around the threads, or do you use a dab of Permatex gasket maker, or do you use nothing?
    When I took my old one out as part of the engine sump removal, I think it possibly had a smear of silcone RTV on it, but I can't be certain.
    Thanks as ever.
  2. ulf308qv
    ulf308qv Karting
    Nov 1, 2003
    100
    Sweden
    Ulf M
    I can't remeber if the sensor has one or two terminals. If it has one, it will ground through the treads so be careful with sealant. I think it has NPT style treads, so no sealant would be required.
    Maybe someone else can confirm this.
  3. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    It's a single terminal. I was wondering if the threads are sufficient to seal it without any additional assistance ... they probably are.
  4. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,280
    Illinois
    The NPT type threads self seal, so no extra sealant is needed. The threads are tapered to fit well as the unit is tightened in.
  5. f355spider
    f355spider F1 World Champ
    18,048
    +1, but I put thread tape on anyway. And it worked fine too. ;)
    The old Veglia one I removed had some hard, white congealed putty or something on the threads.
  6. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
    I believe the threaded part of the sensor act as a ground since the the single wire is the the signal wire.
    Make sure it's tight enough that you get good ground contact and don't put too much teflon/sealant as
    this will reduce ground contact and may give you inaccurate reading or no reading at all.
  7. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I always use teflon tape on pipe thread fittings. 1 1/2 wraps and then check with a test light to verify if it is grounded.
  8. peter_x
    peter_x Rookie
    Mar 4, 2008
    11
    If you were to use teflon tape, I think you use the yellow one, which is fuel/oil resistant, not the white one, which is for water.
