Oil type question for 360 engine | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Schumi76, Mar 27, 2006.
  1. f355spider
    f355spider F1 World Champ
    18,055
    Cliff,
    everyone may have an opinion, but that information has to be take for a grain of salt. 5w (single grade) may be as "thick as water" at operating temp, but not a 5w-30 or a 5w-40...it will be either a 30 or 40 weight as specified...that is how modern multi-weight oils work. Thin oil is not necessarily a bad thing, as long as you have proper oil pressure showing on your oil pressure gauge. Again, highly recommend you review Ali Haas' motor oil articles, they are very interesting to read. He dispells many myths that are often taken as fact these days...sure was an eye opener for me, and greatly enhanced my understanding of motor oils and viscosity.
  2. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Dave, thanks, yup, makes sense. I'll check out the information Ali Haas has accumulated. Agreed, a lower wt is not a problem in itself provided sufficient pressure is present. Just checked my owner's manual for the 3.2 mondial I have and it does spec 10/30 for the temp range I'm in (WA state) so I think I'll stick with that for now for the heck of it. Again, thanks.
  3. can'tdrive55
    can'tdrive55 Rookie
    Mar 10, 2006
    7
    only shell ultra helix. there is nothing better.
  4. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    someone needs to read more.
    Shell Helix Ultra RACING 10w60 is quite good. BUT, The Helix Ultra recommended by the factory is only for marketing reasons. In normal use, it's not bad, but in any extremes (heat/cold/rpm/track etc), it doesn't do the job as well as other brands.
