Oil used in a 330 GTC | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by massimofinance, Apr 4, 2011.
  1. massimofinance
    Nov 24, 2004
    39
    What kind / weight oil do you use in your 330 GTC?
    M.
  2. JazzyO
    JazzyO F1 World Champ
    Jan 14, 2007
    12,156
    The Netherlands
    Onno
    The previous owner of 22 years swore by Mobil 1 20w60, and it seems to do a great job. Expensive though.
    Onno
  3. Motob
    Motob Formula 3
    Nov 11, 2003
    2,370
    Frederick, Maryland
    Brian Brown
    I recommend Brad Penn 20W-50, as all of the other oils have had the ZDP removed from them. Mobil one is also not very good anymore, and synthetic oils tend to leak more on older motors.
    Brian Brown
    Patrick Ottis Co.
  4. shaughnessy
    shaughnessy Formula 3
    1,869
    Wolfeboro NH
    Thomas E Shaughnessy
    I second Brad Penn oil recommendation.
    I have been informed with the exception of Mobil One Racing most store bought Synthetic oils are only high grade petroleum products that have similar characteristics to synthetic oils.
  5. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,080
    San Francisco Area
    John Vardanian
    Hi Brian, how does ZDP or lack of it come into play, just curious? Thanks.
    john
  6. ArtS
    ArtS F1 World Champ
    Nov 11, 2003
    13,401
    Central NJ
  7. John Vardanian
    Jul 1, 2004
    3,080
    San Francisco Area
    John Vardanian
  8. JazzyO
    Jan 14, 2007
    12,156
    The Netherlands
    Onno
    My memory is not as good as I thought it was - it's Motul LeMans 20W60 according to the service records.
    Onno
  9. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    No issues running a 20W60 oil? I would have thought that a "60" weight oil would be too thick?...
  10. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    I have been using Mobil 1 20W50, but for motorcycles which has an API rating of "SG" (= 1600 ppm of zinc & phosphorous).
  11. JazzyO
    Jan 14, 2007
    12,156
    The Netherlands
    Onno
    #11 JazzyO, Apr 6, 2011
    I have records to prove it was 60, car ran fantastically well on it. But I've just checked, and the owner's manual lists 40. Quite a difference. Comments from the community here?
    Onno
  12. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    The reason I asked was that, while I mentioned above that I'm using Mobil 1 20W50 motorcycle, I'm thinking for this upcoming oil change, I'd like to try AGIP Racing 4T 10W60... Has the same API spec of "SG". My only reason for change is that years ago I ran Castrol Syntec 5W50 and liked how the lower weight at cold made the car idle smoother at start-up. With this 20W50, the idle speed is a tad bit sluggish at cold, start-up. I figure the 10W60 may improve this, but concerned of the thicker weight at higher engine temps (in that it might not lubricate it as well as the thinner, 50 weight).
    I'll be phoning the Canadian AGIP rep. soon to try to get some info on this oil... I'll make a suggestion to them they should reissue SINT 2000 10W50 for our classics. ;)
  13. Texas Forever
    Texas Forever Eight Time F1 World Champ
    BANNED Rossa Subscribed
    Apr 28, 2003
    85,600
    Texas!
    Well, if you're gonna reuse your oil, I suggest getting one of those gold mining pans to sluice the metal out before putting back into the motor. :)
    Oh, and make sure you save the metal shavings in case you ever want to do the classiche thing.
    Dale
  14. massimofinance
    Nov 24, 2004
    39
    Thanks for all the replies. Think the Brad Penn 20w 50 is how I will go. Amazon has it for $4.95 a quart. Only other question is does anyone know of either an online tutorial or written online directions to changing the oil? Want to do it myself. I've changed oil before in other cars, just want to try to catch those little bits on info and advice that you find.
    Thx.
    M.
