oil volume | FerrariChat
oil volume
Discussion in 'Technical Q&A' started by 95spiderman, Nov 17, 2003.
  1. 95spiderman
    95spiderman F1 World Champ
    17,433
    ny
    i've asked this before but still do not know whats happening when i have oil in 348 changed. total volume should be about 10 qts but only takes 8 to get to middle of dip stick when warm.
    mechanic has good exotic experience and says he drains both sump and block and pressure are normal so what could it be?
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,948
    The Cold North
    Tom
    you have to remember that you will not get every bit of oil out of the car on an oil change. The oil cooler the lines,and even sump and the tank will still have some oil left in them even after a thourgh draining. The capacity staed in the owners books are for a dry and empty system including the oil cooler.
  3. TCM
    TCM Formula Junior
    Nov 10, 2003
    552
    Tyngsborough, MA
    This may sound very stupid, but are you sure the correct dipstick is in the car. Many times, people accidently put the wrong dipstick in a car after changing the oil (if there are other cars getting the oil changed at the same time). Could it be possible that there is another Ferrari's dipstick in your engine? While I agree that the engine is going to hold more oil then is drained, it should not hold an extra 1.5 quarts. Please keep us updated if you find the problem.
  4. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    The 575 Maranello uses 12 qts for the basic oil change, 16 if I empty all the lines to and from the engine and to and from the oil cooler, huge difference!
    aehaas
  5. Aeroengineman
    Aeroengineman Formula Junior
    Oct 5, 2003
    897
    Maple Valley, WA
    Dave Tegeler
    I have changed the oil in my '97 355 Spider Three times and it always takes 8-1/2 quarts. I got fooled the first time and put in too much and had to suck a quart out. - Its just the way it is!!!
  6. Standig
    Standig Karting
    May 13, 2002
    152
    Spring Hill, Fl
    Stan DiGuiseppi
    How are you checking the oil....
    You have to check oil after the engine is warm and just after you shut it off. Don't fill to the full mark. Half way is good.
  7. TOM B
    TOM B Formula 3
    Jul 24, 2003
    1,038
    Orange County, NY
    Thomas Buckley
    My 3.2 Mondial takes 8.5 qts. for an oil change. Even though i've changed the oil many times, I always underfill it initially . I'll put in 7.5 qts, and while it is still on jackstands, let it warm up and check for leaks. I then shut it off, wait 15 minutes and check the oil. Inevitably, I end up putting in the remaining quart and bringing the level up to FULL. From ADD to FULL is 2 qts.
    Using this procedure, i've never overfilled any car.
    Tom
  8. Aeroengineman
    Oct 5, 2003
    897
    Maple Valley, WA
    Dave Tegeler
    My 8.5 quart measurement is with the engine oil at 150 degrees having immediately shut off the engine and measureing to the "Max" mark on the dipstick. Stated capacity is 10 quarts. I drain the crank case and the scavage tank. Different from the 348 I had to cut a 3" hole in the aerodynamic fairing on my drill press to gain access to the tank drain plug on successive oil changes. This is a lot better than removing the aero fairing and potentially wearing out the studs that hold it on.
  9. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    360's take about 9 litres on a basic oil change. However, after an engine rebuild with washed housings and parts, cooler and lines flushed, they take up to 14 litres.
  10. dennis_maine
    dennis_maine Karting
    Sep 11, 2007
    196
    ME
    Dennis Haines
    I just changed the engine oil and filter in my Mondial 8. I put in 9 quarts (takes 9 liters) and it was seriously overfilled. Any ideas why?
  11. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    see above
  12. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    So if it says 9 liters then why would you put in 9 quarts. Considering a quart is greater then a liter you would have more oil then the car calls for. Is this a trick question. Also if you measure the oil on the dipstick cold after you change it you will see it is a few inches over the full mark. When you measure it according to the owners manual you will see it is at the full level.
  13. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    You typed that in wrong, correct?!
  14. Llenroc
    Llenroc F1 Veteran
    5,493
    Colorado
    Vern
    I see this is an old post but thought I would answer anyway. There is a qt. in the oil cooler and an easy 1/2 qt remaining in the engine, oil lines, sump etc. add in the 1/2 qt based on your dipstick reading and you have the missing 2 qts.
    I have 2 oil coolers on my 355CH and I have to remove them and turn them upside down to completely get the oil out of them, I get 3 qts that I would not get when just draining the tank and sump!
  15. Steve King
    Feb 15, 2001
    4,367
    NY
    Right 1 liter = 1.056 qts. So 9 liters should be 9 1/2 quarts. It would have been nice if the packaging industry converted when the auto industry went metric.
  16. dennis_maine
    Sep 11, 2007
    196
    ME
    Dennis Haines
    OK, thanks to everyone who replied. 9 quarts is less than 9 liters, I don't yet have an owner's manual (on backorder), but now that I know about checking the level 15 minutes after shutdown I will try that. Maybe the problem is the oil remaining in the cooler and lines.
    On the same subject, I bought K&N oil filters, which are supposed to be correct, but I have to wait for oil pressure after starting, so I don't think they have the anti-drainback valve. Is there a filter that does? Also, I can't find a local source for 10W-50, so am using Syntec 20W-50 until I can find the right stuff. Anyone know of a source of 10W-50?
  17. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Why are you using such an overly thick oil?
  18. Steve Magnusson
    26,785
    It's not the anti-drainback valve that you are missing in the K&N, it's the internal standpipe that works in conjunction with the anti-drainback valve to hold more oil inside the (inverted) oil filter case. Do a search on "Baldwin standpipe" -- Baldwin B253 is what you need.
  19. Glassman
    Glassman F1 World Champ
    It depends on the model of car of course, but for a 308 20W50 is not overly thick unless you really enjoy scary low oil pressure when warm.
  20. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    I don't know if I'd call 20w/50 overly thick, the non-synthetic version has been used in my '84 V12 for many years with very good results. I have heard that the synthetic types could possibly effect internal seals (don't know how true it is---but any rumors @ possible internal problems I steer clear of at the risk of an expensive rebuild).
    I seriously recommend Ali Haas's research document on motor oil to better understand .........
    http://www.ferrarichat.com/forum/faq.php?faq=new_faq_item#faq_haas_articles
  21. f355spider
    f355spider F1 World Champ
    18,044
    If Castorl is your preferred brand, use Castrol Syntec 5w-50 or 5w-40. Both can be found at any AutoZone store.
  22. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Gentlemen, with all due respect, I believe that you will find that AEHass advocates, strongly, lighter weight oils because most engine wear occurs at cold-engine-startup when oil is too thick to circulate.
    Obviously a few track cars will be running so hard for so long at such high temps that *they* will require heavy oils, but I suspect that few street cars will benefit from trading startup wear for high-temp, high RPM (for long periods) protection.
  23. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Yes. 5W50 is a *vastly* better option than 20W50.
    5W50 basically means "the oil flows like a 5 Weight oil when cold" and that "the oil protects like a 50 Weight oil when hot."
    20W50, in contrast, basically means "the oil flows like a 20 Weight oil when cold" and that "the oil protects like a 50 Weight oil when hot."
    Which is to say, you lose startup protection with 20W over 5W because 20W takes so much longer to lubricate your engine properly at startup (at least when the engine is cold).
  24. Glassman
    A lot of us do not want to use synthetic. Yes I know, I'm a cheap ass for not replacing seals the second I find a leak, and probably don't deserve to own a Ferrari. But there just isn't a dino oil that I can find locally with a weight less than 20. And after trying 10W40, I will never make that mistake again. I am very happy with 20W50 and will leave that issue in my life at rest.
  25. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Point taken.
