Oil | FerrariChat
Oil
Discussion in 'Mondial' started by Chris Mondi, Sep 2, 2020.
  1. Chris Mondi
    Chris Mondi Rookie
    Oct 30, 2018
    48
    Chris Riedinger
    which oil are you guys using? is there a consensus on which is best?
    I started developing a few small leaks on my 3.2 this spring and didn't realize that my mechanic had switched to Amsoil 10w-40 full synthetic this year. The car hadn't leaked at all for two year prior while using a different oil. Anyone else experience the same thing?
  2. John Hasty
    John Hasty Rookie
    Jul 16, 2019
    45
    John H. Hasty
    Mobil 1...no problems
  3. swong46
    swong46 Karting
    Jun 24, 2015
    137
    Bay Area, CA
    I am using this, Miles 15w40 CK4. Used to be an amazing deal at $40 for a 5 gallon bucket with free shipping but price has gone up every year...
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,577
    San Carlos, CA
    Mitchell Le
    You know, the guy who owns Blackstone Lab that does the used oil analysis was asked that same question. His answer: "Whatever is on sale." Any brand name oil is good to him and he did a few million samples.
    dmarti02 likes this.
  5. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    Your leaks would be unrelated to the brand/viscosity of oil - synthetic was standard from factory on the 3.2, and can (should) be used now without any issues. A 5W-40 or 10W-40 synthetic is ideal. I use the Pennzoil Platinum Euro 5W40, it's the Ferrari-endorsed grade. The oil leaks are likely from seals or hoses that have dried up a bit, it's a continuous battle to keep ahead of the little leaks here and there.
    ronfrohock likes this.
  6. ronfrohock
    ronfrohock F1 Rookie
    4,157
    MA
    Ron Frohock
    I’ve been using Brad Penn. I’m told it has the correct amount of zinc and other additives to keep our cars happy.
  7. ronfrohock
    4,157
    MA
    Ron Frohock
  8. Chris Mondi
    Chris Mondi Rookie
    Oct 30, 2018
    48
    Chris Riedinger
    I’ll respectfully disagree. There’s too much evidence to the contrary
  9. Chris Mondi
    Chris Mondi Rookie
    Oct 30, 2018
    48
    Chris Riedinger
    Hi Ron, that has been highly recommended to me by a few people. Also Valvoline 20w-50 vr1 has been mentioned a few times
  10. ronfrohock
    4,157
    MA
    Ron Frohock
  11. John Hasty
    John Hasty Rookie
    Jul 16, 2019
    45
    John H. Hasty
    Brad Penn & Valvoline racing oils are designed for older flat tappet motors like my TR3A race car . I would think they are not suitable for our Ferrari's
  12. boxerman
    boxerman F1 World Champ
    19,739
    FL
    Sean
    These ferrari motors are flat tappet.
    I use Brad Penn in my BBI, as sodes evreyone else I know.
  13. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    Nope. "flat tappet" as referenced by all the oil threads discussing ZDDP zinc content refers to old American V8s with overhead valves, a single camshaft with flat tappets pushing long, heavy pushrods, rocker arms, 2 big valves with heavy springs - a LOT of valve train mass and inertia causing very high forces on the cam to tappet face. Our double overhead cam directly acting on buckets over 2 or 4 light valves and relatively soft springs have a fraction of the cam-tappet forces on them than the actual "flat tappet" V8s do, so we don't ever experience the excessive wear on the tappets or need especially high zinc content. It's become a common misunderstanding that any cam follower that is flat is what is meant by "flat tappet".
  14. 88MONDIAL
    88MONDIAL Formula 3
    Apr 13, 2005
    1,052
    Racine, Wisconsin
    Jim Smith
    Valvoline VR1 20w-50 Racing oil. Hi zinc. The one my mechanic puts in and the one I was told to use for these cars.
  15. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    I believe the leaks would likely be worse with synthetic oil. But you can assemble a motor that does not leak, if you use silicone gasket sealer. A particularly leaky spot is around the cam O-ring area. This gets worse over time.
    I live in the tropics, so use a heavy 20w-50 racing oil. This is likely too heavy for cold climates. The thinking these days is to use light 5w oils to prevent sludge build up. This won't happen if the oil is changed regularly. Synthetic oil itself will last a long time, but it will still get contaminates in it. So I think it's best to change it out at regular intervals, say 3,000 miles. JMO.
  16. AUDIO RESEARCH
    AUDIO RESEARCH Formula Junior
    Feb 11, 2009
    394
    PHILIPPINES
    LUIGI RAYMUND LIRA
    Mobil 1 15w 50 . I changed the oil once a year even if the car is only used every Sunday for 30 mins of spirited driving .
