OK with wider tires? | FerrariChat
Discussion in '360/430' started by stnilsson, Feb 22, 2011.
  1. stnilsson
    stnilsson Karting
    Jul 4, 2007
    150
    Helsingborg
    Stefan Nilsson
    I have got an offer to buy four brand new Bridgestone Potenzas at a very good price.
    Rears are right size 18" 275X40 but the front tires are 18" 225X45 when they should be 215X45, do you think its ok. The car is a 360.
  2. cavallo95
    cavallo95 Formula Junior
    Jan 23, 2007
    272
    chicago
    #2 cavallo95, Feb 22, 2011
    Width should be fine, but overall diameter will be 0.4" bigger then stock , good luck!
  3. ferrariblue
    ferrariblue Formula Junior
    Jun 12, 2007
    548
    Houston, Texas
    Cody
    The oversized front tires will certainly tear your front fender edges up. You need to stick with stock sizes. I have personally seen a 360 take damage due to the wrong front tires.
  4. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Even from going wider on the front by ONE size/width?? :):)
    How wide were the tyres on that 360 to have caused damage to the front gaurds? :):)
    Going one size wider on the fronts would seem fine to me. But I dont own a 360, so I wouldnt know. :D:D
    One would assume 10mm wider tyre would still have clearance under the gaurds on the 360. :):)
  5. F430addict
    F430addict F1 Rookie
    Sep 17, 2010
    4,460
    Especially when the suspension is at stock height. Yes, I'd agree with you as well. If it has been lowered, then it's a completely different ballgame.
  6. rbf41000
    rbf41000 Formula Junior
    Nov 21, 2005
    698
    Delray Beach FL
    Russell
    People have complained about standard tires on stock ride height catching the front fender lip when turning full lock.
    Fender rolling is the answer.
    Russell
  7. JS NZ
    JS NZ Formula Junior
    Sep 24, 2010
    305
    Auckland, NZ
    I have damaged my lh fender with original size tyres, splitting the lip. It is a very common problem. I also have those tyres on SA02A??(still sold in this part of the world), the replacement equal in US is called something else I think. They are ok but I get the ASR light coming on under hard acceleration a lot more than the P Zeros( but they were 2x the price).
  8. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    Not true. The 255 will mess your fender. Im running with 245 at front with 19" wheels and it just fine. Try it and you will be just fine.
  9. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Thanks guys!! :):)
    Now, this is interesting! :D:D
    Stock tyres rub on the front guards with 215 and you are running 245s and dont have a problem? :D:D
    Perhaps your offset is a little different to the stock wheel David? :):)
  10. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    Yeah, I think you a right PAP.
  11. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Ah huh!! Always an explanation for everything. :eek::eek:
  12. hangarsixco
    hangarsixco Formula Junior
    Oct 10, 2010
    396
    S. California
    Chris
    +1
    I have 255/30/19 on my 360 no issues, now I am not slammed like others but the car is lowered. I have no clearence issues at all. Good luck.
  13. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Assuming fender clearance is ok, the other issue would be changing the stagger. 360s are already a bit tail happy (compared to 430s), so going to a larger front size while keeping the rears the same will aggravate oversteering tendencies.
  14. F355F1 Berlinetta
    Mar 13, 2010
    142
    Norway
    REV
    I got 255/30-19 in front and 355/25-19 rear:) No problem.
  15. ferrariblue
    Jun 12, 2007
    548
    Houston, Texas
    Cody
    I'm assuming the people chiming in with oversize tires in front with no issues have aftermarket wheels with a different offset. I owned a 360 and now an F430, and my 360 had stock wheels (starfish), and stock width in front. My tires still caused some minor bending of the inner fender lip with a complete stock factory set up. My Ferrari dealer said it's an inherent issue with the 360 model.
  16. F355F1 Berlinetta
    Mar 13, 2010
    142
    Norway
    REV
    Yes It Is aftermarket wheels, I got Novitec.:) And they are wiiiide:)
  17. VividRacing
    VividRacing F1 Rookie
    Aug 23, 2005
    2,986
    Gilbert, AZ
    355 is wide, I had 345 and they were overkill. I bet it looks sweet though.
  18. F355F1 Berlinetta
    Mar 13, 2010
    142
    Norway
    REV
    They look awsome:)
  19. tazandjan
    39,175
    NF1s and NF2s are 9" F and 12.5" R compared to 7.5" F and 10" R OEM. I have NF2s on my 575M and they are very, very wide, especially in the rear, but work fine on 360s (and 575Ms).
    The difference in height and width on a 225/45 vs a 215/45 tire is small for a tire, 25.97" vs 25.62", and only half that difference (0.18") is sitting above the wheel center line. 10 mm width difference is only 0.40", half of which is on either side of the wheel, or 0.20". For a stock ride height car, that will not make much of a difference unless you are at full lock going over big bumps. So you have about 1/5" more rubber in two directions.
    Taz
    Terry Phillips
  20. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Any pics Rev? :D:D
  21. hangarsixco
    Oct 10, 2010
    396
    S. California
    Chris
    Yes aftermarket wheels on mine. 355 Pirelli in the rears as well.
  22. djastral69
    djastral69 Formula 3
    1,896
    Fl
    David
    Just roll the fenders, problem solved :)
