Old head gaskets? | Page 2 | FerrariChat
Old head gaskets?
Discussion in 'Technical Q&A' started by Ferrarium, Nov 2, 2021.
  1. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Yes apparently so. Odd because it drilled like steel left flakes like steel is heavy like steel and if I recall my magnetic tool tray stuck to it. I'll check when they come back from the shop.
    Sent using FerrariChat.com mobile app
  2. Turbopanzer
    Turbopanzer F1 World Champ
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
    And you believe GM? I got a bridge i would like to show you...:D
    Your assessment of engineering was correct. No different at the blue oval. Crap is crap and those that design it generally have little pride in craftsmanship.
  3. raemin
    raemin Formula 3
    Jan 16, 2007
    2,388
    Lyon (FR)
    R. Emin
    @jjtjr & @Turbopanzer : collant leak additives is still a valid question... I've had so much trouble with my cylinder heads that I am actually considering additives (after) the rebuild.
    When we crushed the dome of my head in order to fix a few cracks, I've had the opportunity to see how thin the inlet and exhaust ports are (1~2mm max). These are almost impossible to weld (ask me how I know) and hard to source. I was given 2 heads, bought 2 more, and it's only on the fourth iteration that I've managed to find a head with no cracks! Bottom line, most of these heads will experience some leak after a few decades.
    I would reluctantly use thick fibrous materials (such as the GM tabs), but maybe that a liquid leak sealant would make sense as a pre-emptive measure?
    Would be interested to have opinion on this issue.
  4. Turbopanzer
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
    @raemin ....liquid sealants pose several problems. One...they affect other components such as water pump impeller and bearings. Two...depending on the type of liquid, they can attach themselves in critical areas to create hotspots. Either can shorten both component life and or heat related valve train problems. Depending the areas of cracking, it would be best to consider consulting a aluminum cylinder head specialist. This is not a job for the local machine shop doing mass production work. There are several that can help identify and correct the related problems.
