On Car Wheel Balancing | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by rickard, Sep 21, 2007.
  1. rickard
    rickard Rookie
    Apr 13, 2007
    38
    toronto canada
    rick impera
    I thought I'd share this with fellow F-chatters. I just had the wheels balanced on my car with a piece of equipment that would spin the tire while it is on the car. By doing this ,the technician that was operating the equipment was able to remove the slightiest vibrations that would run throughout the entire car, such as removing viibrations from the steering wheel, shifter and even seats . It seemed that he was tuning a fine instrument, adjusting and tweeking the weights until the wheels and the car were happy as one. When I drove the car home, it was as smooooooooth as silk.
    I told this story to a friend of mine and he thought that this whole process was a waste of time and money. By balancing the tires, the traditional way would have been just as effective, because everything on the car is balanced anyway. What are your thoughts?
    Rick
  2. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    what kind of wheel balancing machine/set-up was it? What were the associated costs (because of the 'waste of $ remark)?
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Your drivetrain should be balanced when it's new but nothing says that it still is after 32 years of wear and ??? repairs.
    Your friend might be an idiot.
  4. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    Rick
    Be sure to mark your wheels as to which hole goes where onto the hub. If you remove a wheel and don't put it back exactly as it came off the car when it was balanced, you will now have an imbalance. In effect, you balanced your wheel hub with the wheel. If you re-orient them they will be out of balance. It is not impossible to keep track of them but some extra care will be required.
    These machines have been around for 30 years or more, but they are not a perfect answer. Enjoy your smooth ride while it lasts!
    Ken
  5. Steve Magnusson
    26,785
    I'd say this a little bit differently -- it would be unusual for the other components to be significantly unbalanced because their radius is not so big, and they tend to be symmetrically-made and machined with decent precision (although sometimes you'll see weights added to a cast brake rotor or drum to balance it as an individual component).
    What was the unbalance feedback mechanism that the Mechanic used? Just by hand feel, or did he have some sort of instrumentation that mounted somewhere? I'm thinking that it would be difficult to do a two-plane balance on each wheel/tire/hub/rotor since the spindle axis of the wheel would resist any moment perpendicular to the rotation axis.
  6. Llenroc
    Llenroc F1 Veteran
    5,493
    Colorado
    Vern
    I haven't seen one of those balance machines around for years(early 70s) they claimed it would balance the brake disc/drum along with the wheel and tire. I remember the quality of balance to be good also but, of course that was comparing it to a bubble balance. How old was the machine do you know?
  7. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    well u'all things in balance do become unbalanced. my shop has at least one job a week. balance weights fall off. people bend parts driving. and parts rust/ ware out.
  8. rickard
    rickard Rookie
    Apr 13, 2007
    38
    toronto canada
    rick impera
    Thanks for the great responses. I'll give more details on the type of machine that was used.
    The cost of the on car wheel balancing (Canadian=US dollars) was 138.00 tax in. The whole procedure took 1 hour incl. yapping time.
    Rick
  9. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    Had this done perhaps twenty five years ago and the equipment was old then. Haven't seen this done since.
    The results were very good but this precludes tire rotation and also requires the wheel to be properly indexed to the (proper)hub.
    I guess what's old is new again.
    Who is doing this now?
  10. boxer frank
    boxer frank Karting
    Sep 30, 2004
    165
    toronto canada
    FRANK
    brake rotors are balanced by manufacturer
    only way to know forsure is to immediately balance wheels only on a modern conventional wheeloff balancer
    hey rick what part of the city are you in iam close to picking up a gt4 and would love to see your car
  11. dstacy
    dstacy F1 World Champ
    11,998
    GMT -5 & GMT +1
    Dave
    Which GT4 are you buying?
