Once more with feeling - window switches | FerrariChat
Discussion in 'Mondial' started by tdskip, Oct 12, 2022.
  1. tdskip
    tdskip Karting
    Aug 25, 2012
    185
    SoCal
    Tom
    Good morning gentlemen – hope everybody’s having a good week so far. With your help I got my 1988 window switches working but that has proved to be short-lived and despite cleaning them extensively electrical contact cleaner I cannot put my windows back up although the downward direction on the switch works perfectly fine of course.
    Not be able to put the windows back up is interfering with my ability use the car and since we’re getting a prime driving season here in Southern California I really wanna get this taken care of.
    My inclination is to simply get brand new switches and from previous discussions here I believe those are the same as 308 units?
    thank you in advanced for any coaching that you could offer.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    First off measure the volts you are getting at the motor terminals in both directions, it may be you are shy on volts. You can buy a window boost kit from Superperformance in uk for little money which might help.
    Your fuse box might not be giving u enough volts
    85cab and tdskip like this.
  3. tdskip
    tdskip Karting
    Aug 25, 2012
    185
    SoCal
    Tom
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    What switch part number are you looking for. The superperformance site shows a few for the mondial T, 308/328 etc
  5. tdskip
    tdskip Karting
    Aug 25, 2012
    185
    SoCal
    Tom
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    Look up Eurospares in the uk- get onto ferrari spares and select your exact model, this will give you all the drawings and parts list.
    Your pt no 61047700 has been super seeded by 64880400 but showing as available to order.
    If you put ferrari followed by pt no in google you will get a lot of info, like e bay used parts.
    Look on superperformance site in uk , V8/ mondial/ your model - select electrical from side menu- shows all the window bits
    tdskip likes this.
  7. tdskip
    tdskip Karting
    Aug 25, 2012
    185
    SoCal
    Tom
    Well...everyone I have contacted says they are out of the original and superseded part number.
    I have to think Alfa or Fiat used similar switches so think I am going to pull one and run over to a local Alfa shop and see what ideas they have.
    Short of that I may just wire up a work around since it is driving me BONKERS not to be using the car, especially since cooler weather in SoCal makes for great driving.
    Open for any/all creative ideas!
    Hope everyone is have a good week so far.
  8. 85cab
    85cab Rookie
    Jun 30, 2015
    40
    Ottawa, Canada
    With your battery fully charged, did you check the voltage at the motor (both directions) as suggested by Mike32 in post #2.
    Due to the weight of the window glass (and gravity) it’s not uncommon for a poorly powered motor to still have enough power to lower the window, but to struggle when lifting.
    Another common issue with the motors is a build up of old grease inside the gearing mechanism of the motor. As this grease hardens, the friction created impedes the free movement of the gear wheel. There are a few posts on this site that outline how to remove the motor, clean and re-grease the inner workings.
    Same applies to each of the wheels/bushings over which the window cable travels. You’ll want to be sure all of those points move freely.
