One bank no spark after engine installl | Page 3 | FerrariChat
Discussion in '348/355' started by F355Bob, May 30, 2017.
  1. m.stojanovic
    m.stojanovic F1 Rookie
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    Looking at the 2.7 348 diagram (355 could be similar), the +12V supply to the middle pins of the coils has no relays or fuses; it goes from the ignition switch, goes only through the main fuse box, splices out into two wires inside the fuse box which come out at fuse box connector "F" as Yellow and Yellow/Black, Yellow (1-4) to pin 9 of inline connector 119, Yellow/Black (5-8) to pin 9 of inline connector 118. The connectors 119 and 118 are shown on the diagram to be near the ECU-s but may not be really there. After this, the Yellow and Yellow/Black both go to the inline connector No. 1 and from there to the ignition coil middle pins.
    If you don't get ignition switched +12V on the middle pin of the coil for the non working bank, the main suspects are the connectors 118 (or 119) and 1.
  2. Qavion
    Qavion F1 World Champ
    14,507
    Ian Riddell
    #52 Qavion, Jun 2, 2017
    If they're detecting the trigger signals from ECU pins 1 & 20 without removing the plug from the ignition power module, then indeed it could be an earthing problem (or an ECU problem).
    If you can't find the specific ground for that circuit (#70046), then perhaps you can compare the resistance between pin 4 of the ignition power module and any known good ground in the engine bay, with the resisitances from the RH engine ECU plug sockets #14 and #24 to that same good ground. i.e. with the ECU and power module not plugged in. Also compare it with the O2 heater earth wire to ground. These wires are spliced together, so the resistances should be similar. If not, the splices may be faulty. If they are similar, but perhaps a little high, perhaps it is the unknown ground itself which is not secured properly.
    Grounds diagram
    I had a look around my car (5.2), but couldn't find a ground for my 02 sensor. Anyway, the 2.7 and 5.2 circuits are too dissimilar. When I first bought my car, I had a baffling turn indicator problem which also affected the brake and reverse lights, but only when the car was warm. I eventually found an earthing point above the LH radiator outboard support bolt. There's one on the opposite side, too.
  3. Qavion
    14,507
    Ian Riddell
    I think Bob is saying that the weak signal is between the ECU and the power module (rather than to the coil pack), Miroljub.
    Cheers,
    Ian
  4. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    I have not looked at the schematics and therefore have no idea how the ignition system is triggered but I'll throw this out there just in case. If the ignition is triggered by separate position sensors for each bank and if that trigger signal passes through the ECU unaltered it is possible that the air gap on the position sensor is too large. Again, probably not even a possible scenario but easy enough to check if it's remotely possible.
  5. F355Bob
    F355Bob Formula 3
    This is great stuff. Really appreciate it. We checked the air gap and it is right to specs.
    Will bring the info to the mechanic and hopefully we get it started today.
  6. Qavion
    14,507
    Ian Riddell
    What was the reason for the rebuild? Were you having problems before this. I'm a little concerned that you didn't have a spark problem beforehand.
    The mechanics said you were getting a weak ECU/power module trigger signal (and I assume it was at the right rate), but it was present. How can the air gap between sensor affect the strength of the signal from the ECU to the ignition power module? The ECU is just getting timing signals from the sensor and using them as a baseline for its output signals. It can advance/retard the timing of the spark firing to get the best engine performance. If it was a sensor gap problem, wouldn't the ECU either not get a signal and not trigger a spark or get intermittent signals and only send the occasional spark trigger? If it got any trigger signal from the sensor, the ECU would still output the same strength signal to the ignition power module (unless the ECU was faulty or there was a high resistance in the circuit (e.g. caused by a bad ground)).
    Unless we're missing something here, I think your best bet would be on something being broken when the engine was removed or installed.. or someone forgot to tighten up a ground wire properly somewhere.
  7. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,813
    Lake Villa IL
    If I remember correctly this car has piggyback ecu's for fueling. They must share multiple sensors with the stock ecu's.
    Have the splices been checked on everything?
  8. F355Bob
    F355Bob Formula 3
    Went over this morning to show some of the print outs that others have supplied and they had just got the car started and running on all 8 cylinders. It turned out it was a grounding issue. They went back and took apart the grounds, cleaned everything and it started right up. I am going to add a few more grounds this summer. It's funny that we always look for the more complicated solution and sometimes it turns out to be the most simple solution. Thanks to everybody who had suggestions and gave information. It was an expensive journey but maybe we all have more understanding of the car. Grounds are important!
    The car had a rebuild to redo the last rebuild from Gary Sharpe. Engine was striped if everything and completely rebuilt. Once I get things sorted, I'll post a write up of the rebuild . Their just finishing doing the final install of airboxes etc, and are planning on running it a little on their chassis dyno to get a few miles on it before I pick it up hopefully this afternoon. Thanks to everybody again.
  9. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Thats great !!!!
    Yes I ground the heck out of everything
    Always remember 90% of the time if a new issue arises, its something you took off..
    Glad you found it
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,662
    San Carlos, CA
    Mitchell Le
    Oh, that says something right there.
  11. WATSON
    23,909
    WI
    It sure does!
    Poor Bob had the full Gray Sharpe treatment. Glad he is getting his car exorcised :)
  12. Qavion
    14,507
    Ian Riddell
    I wonder where that mysterious "70046" ground was. It would have been handy to know.
    Anyway, good to hear it has been sorted.
  13. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    So is Gary not so Sharpe.
    What did he do!
