One Blower switch not working | FerrariChat
Discussion in '308/328' started by Rod, May 22, 2019.
  1. Rod
    Rod Formula Junior
    Jan 18, 2004
    869
    South Derbyshire
    Rod
    RHD 328gts,,, The left side blower switch is not working. any ideas where to start? Unlike the right one which works and the dash light appears. Nothing on the left one... any pointers would be appreciated..
  2. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    First, I would confirm that the problem is the switch. Once you've done that, replace the switch if necessary.
  3. Rod
    Rod Formula Junior
    Jan 18, 2004
    869
    South Derbyshire
    Rod
    Swap them over?
  4. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    You could swap them, or just disconnect the leads and jump them together.
  5. Rod
    Rod Formula Junior
    Jan 18, 2004
    869
    South Derbyshire
    Rod
    Ok.. will give it a try...;)
  6. Rod
    Rod Formula Junior
    Jan 18, 2004
    869
    South Derbyshire
    Rod
    I've had some time to swap the fan switches over and it seems they both work... as do both of the fans.. Fuses seem ok too.
    It looks like I have no power to the switch. can any one suggest what to try next? A colour wiring diagram would be handy is there one available?
    Also I have no power to my two LED heater switches? any suggestions?
  7. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,153
    Kingsport, TN
    Lawrence A. Coppari
    I am away from home so I cannot look at the fuse panel decal description on my 328 but do the blowers have separate fuses?
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    I have the 3.2 mondial drawings, are they the same ?
  9. Rod
    Rod Formula Junior
    Jan 18, 2004
    869
    South Derbyshire
    Rod
    Thanks.. different fuses... Both ok and both have power to them.
  10. Rod
    Rod Formula Junior
    Jan 18, 2004
    869
    South Derbyshire
    Rod
    I don't know if they are the same?
  11. Rod
    Rod Formula Junior
    Jan 18, 2004
    869
    South Derbyshire
    Rod
    It looks like there is one relay for both heater blowers, is it possible for the relay to be faulty?
  12. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    If they share a relay and one blower works, it's not the relay.
    Rod likes this.
  13. Steve Magnusson
    25,123
    Don't have a copy of the euro 328 wiring diagram book (nor any in colour ;)), but this link will get you the 1986-87 US 328 wiring diagram book:
    https://www.dropbox.com/s/vsxcnaheq1igub4/328%20US%201986%201987%20wiring%20diagram%20book%20440_86.pdf?dl=0
    The injection stuff won't be the same, and typically the euro and US have differences in the external light wiring, but the AC/heating system should be similar IME. Of course, if someone's got a copy of the euro version 328 wiring diagram book, please post!
  14. Rod
    Rod Formula Junior
    Jan 18, 2004
    869
    South Derbyshire
    Rod
    Thanks Steve, much appreciated this will help me for now...
  15. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Drop me an e mail address and will send u what i have re 3.2 mondial
  16. Rod
    Rod Formula Junior
    Jan 18, 2004
    869
    South Derbyshire
    Rod
    Sorted... Turns out that the relay was faulty..... They both now blow.. is it normal for a relay to fail?
    Back to the heating and air cone issue now!
    Any one know what the two plugged relays are? can't see them in the wiring diagram?
  17. Steve Magnusson
    25,123
    #17 Steve Magnusson, Aug 14, 2019
    See pages 96-98 in your 376/86 euro 328 OM.
  18. Steve Magnusson
    25,123
    One is a self-latching relay, with a time delay when deactivated, for your interior lights (so they stay on for a while after closing the door).
    The other is the wiper relay (providing the intermittent wiping functionality)
  19. Rod
    Rod Formula Junior
    Jan 18, 2004
    869
    South Derbyshire
    Rod
    Great thanks.... Do you know what the difference is between the two "A" relays named heater blower and the two "K" relays also named heater blowers?
    One of my "A" relays was faulty which I have replaced. but what do the "K" relays do?
  20. Steve Magnusson
    25,123
    Yes, I noted that the English description of those items was a bit lacking for clarity. They would be better described as:
    75A and 75B (in the wiring diagram Fig 8) = relays running the heater blower motors
    75G and 75H (in the wiring diagram Fig 8) = relays controlling the relays running the heater blower motors
    Whether A = 75A and 75B and K = 75G and 75H, or vice-versa, you should be able to figure out from the wire colors that connect to them. Why they needed two relays working in series to run each heater blower motor = never looked into that...
  21. Rod
    Rod Formula Junior
    Jan 18, 2004
    869
    South Derbyshire
    Rod
    Perfect, thanks for explaining that Steve....
