355 - One Cat is glowing red but no SDL on | FerrariChat
355 One Cat is glowing red but no SDL on
Discussion in '348/355' started by cheungchoyui, Jul 25, 2020.
  1. cheungchoyui
    cheungchoyui Karting
    Oct 16, 2016
    81
    Hong Kong
    Joe Cheung
    Guys,
    I found out one of my cat was red after 40 mins driving.
    No light goes on.
    Any idea ?
  2. Ferrarium
    Ferrarium F1 Veteran
    5,637
    Central NJ
    Eric
    Is the cat ecu connected or bypassed? Is check that first. But generally too much fuel getting in the cat and then being burned there or the cat is clogged. Pull it and do a visual inspection.
    Sent using FerrariChat.com mobile app
  3. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,667
    CT
    John Kreskovsky
    Well, for one, your CAT temp warning system isn't working. And two, looks like that bank must be running really rich or have a cylinder or two out. Three, if a metal core cat it's probably toast.
  4. m.stojanovic
    m.stojanovic F1 Rookie
    2,759
    Malaysia - KL
    Miroljub Stojanovic
    The exhaust glowing red doues not necessarily mean that you were in the SDL trigger zone. I don't know how red the exhaust has to get to trigger the SDL but, when I bench tested a known good 348 thermocouple, I had to heat-up its probe (with a small torch) to bright red/orange in order to bring its output to close to the SDL trigger point.
    I would first investigate why only one side is getting red. Perhaps collapsed cat internals causing some restriction to the exhaust flow?
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    On a 355 (I think this is your car), a red hot cat is a bad sign. You have excess fuel in the cat, even if it has not yet triggered a SDL or a CEL, you need to sort that out before it becomes a fire hazard.
  6. cheungchoyui
    Oct 16, 2016
    81
    Hong Kong
    Joe Cheung
    Thanks for the information. So what should I do to locate the problem ?
    I didn’t feel that I was losing power though.
  7. Qavion
    Qavion F1 World Champ
    11,555
    Ian Riddell
    Have you modified anything on the exhaust system? e.g. O2 extenders with cat material to fool the O2 sensors, dummy plugs on the Slow Down (thermocouple) ECUs, etc? I don't see how the car is not detecting a problem with either fuel/combustion problems or cat temperatures.
    Looks like you have a F355 2.7 car?
  8. eyboro
    eyboro Formula Junior
    988
    Chicago
    Eitan
    Glowing red cats mean loose connections check and make sure you're O2 censors are connected tight
    Qavion likes this.
  9. Ferrarium
    5,637
    Central NJ
    Eric
    1) physical inspection, 02 car ecu etc
    2) pull the cat and look inside for damage/blockage
    3) figure out why it's getting fuel (stick injector, bad fpr, bad plugs) are few easy low cost possibilities.
  10. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    Make sure that you car isn't running too cool. If it is the ecu mapping won't get out of secondary enrichment = extra fuel in the system. Also make sure that your coolant temp sensors are in good shape and sending the correct temp signal.
    drbob101 and Ferrarium like this.
  11. Ferrarium
    5,637
    Central NJ
    Eric
    btw this is why I witched to the 355 fan switch, the 348 switch runs 5 degrees cooler or so with some manufacturing variance..
    ernie likes this.
  12. cheungchoyui
    Oct 16, 2016
    81
    Hong Kong
    Joe Cheung
    Both of the header and cat are aftermarket. Changed by previous owner.
    My car is a 2.7 version.
  13. cheungchoyui
    Oct 16, 2016
    81
    Hong Kong
    Joe Cheung
    This happened after I had 40 mins hard drive. So the car wasn’t running cool.
    Coolant temp has been changed 2 years ago. It seems working fine.
  14. Qavion
    11,555
    Ian Riddell
  15. JL350
    JL350 Karting
    Jan 20, 2013
    205
    Might I suggest a heat gun and measure the temperatures of he banks of header pipes and cats at similar spots to check if there are any real differences between banks and or points in the exhaust system. The colour red is not necessarily a tell tale indicator after a hard run and low light conditions which will make it look brighter than a cat in brighter lighting.
  16. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    You coolant temperature sensor my be just fine.
    However.
    That doesn’t mean your thermostat hasn’t failed.
    Have a read of this thread to understand more about what I am describing.
    https://www.ferrarichat.com/forum/threads/355-owners-only-more-data-samples-needed-anonymous-poll.377706/
  17. GTUnit
    GTUnit Karting
    May 25, 2014
    143
    Socal
    Jack
    Is it running smooth? Unburned fuel is ending up in the cat or the cat is clogged.
  18. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    OR......................
  19. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    He has a failed header.
  20. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    854
    Europa
    Bob
    If you still have the secondary air injection system fitted check for leaks, failed check-valves, cracks in the tubes, loose connectors, stuck open vacuum valves etc.
    Excess air getting in upstream of the cat can cause overheating catalyst (as well as a cracked manifold, as mentioned above or damaged manifold gasket/loose nuts & so on).
    I am personally convinced that a few of the 355s that have gone up in flames have been due to failed secondary air system (although most went to the well documented fuel leaks)
  21. cheungchoyui
    Oct 16, 2016
    81
    Hong Kong
    Joe Cheung
    The air pump is still working whenever cold starts. It run for few mins and stopped. How could it affect the cat when the pump is stopped ?
  22. yelcab
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    What he means is "when there is a air leak close to the upstream o2 sensor, the sensor will read a lean condition where none exists and the computer will richen the mixture during the next combustion cycle. The over rich mixture does not burn completely and ends up burning inside the hot Cat converter, thereby melting the inside of the converter". I have seen it many times.
    spaghetti_jet likes this.
  23. treue
    treue Formula Junior
    Jan 22, 2004
    290
    Oklahoma
    Tom Treue
    Hi Joe,
    We had a Chevette (remember them?). My wife was driving it from Crockett, Texas to Houston about sundown. She called me to say that every time she tried to turn the lights on, the engine would die. Later, a local shop diagnosed it as a bad battery and replaced the battery. I went to drive it that night and it wouldn’t start. I roll started it and tried to drive it back to proper functionality. The engine would not run faster than idle. I drove to a local strip mall parking and lot and drove around in circles. After a few minutes of this, a guy drove over to me and said that there was something glowing under the car! It was the catalytic converter. After a second visit to an auto shop, it was discovered that the alternator was not recharging the battery. When the battery got down to a certain level of charge, there was insufficient electrical current to give a proper spark. Even at full throttle, the engine would not turn more than about 1200 rpm, so any excess gas would go out the exhaust ports and into the catalytic converter where the catalyst would attempt to clean the excess fuel by burning it in the converter and wind up just over-heating it until it glowed. Replacing the diodes in the alternator corrected the problem.
    How well does your car start and run? If my 430 battery had a voltage that was too low (10-11 volts), the starting process sounded quite odd and lacked any alacrity. You might have the battery and alternator checked.
    Tom
  24. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    It may be helpful to check the long and short term fuel trim numbers with a scanner.
  25. spaghetti_jet
    Jan 5, 2005
    854
    Europa
    Bob
    #25 spaghetti_jet, Aug 9, 2020
    Ironically, modern cars actually do a variation of what you describe on purpose in order to get the cats up to working temperature. The strategy is called ‘cold start spark retard’. The spark is retarded and with the richer fuelling for start-up combustion continues in the exhaust manifold. It gets the cats up to working temperature faster and is why cars no longer have secondary air injection.
