ongoing electrical issues | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Shawn Miller, Sep 18, 2008.
  1. Shawn Miller
    Shawn Miller Rookie
    Apr 16, 2008
    14
    Indianapolis
    I was warned by a friend that some electrical parts for these cars have been discontinued, making the car irreparable. It appears that i could need a new computer which I think fits this catagory. Any advice? are there other units available that will work?
  2. aidanparte
    aidanparte Formula 3
    Jul 18, 2004
    1,231
    As far as I'm aware, they don't have any computers. The electrics can be a bit flaky, but nothing so bad as to render the car irrepairable.
    Aidan
  3. Steve Magnusson
    26,785
    #3 Steve Magnusson, Sep 18, 2008
    If by "computer", you mean the Dinoplex ignition module, you could replace it with something else since it only fires the spark and the advance is handled by the mechanics inside the distributor (this is what the BB/BBi guys do typically with MSD units -- so try a search on "MSD"), but you might also need to fabricate some type of new pick-up arrangement/mount too. If you can't find a used one, I'd love to hear if these UK guys can repair it for you:
    http://www.the-ecu-doctor.co.uk
    (As I've got a blown-up TR injection ECU that I'd like to get fixed).
    Alternatively, eurospares shows it as available (and maybe they are doing something special with the guts because they show it as 118112/X rather than just 118112) -- but kind of pricey.
  4. 400iGuy
    400iGuy Formula 3
    1,077
    Central Florida
    Al
  5. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    MSD #6A (does not have rev limiter)
  6. FERRARI-TECH
    FERRARI-TECH Formula 3
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
    Not really a problem on a 400i !!!!!!!!!
    If you are worried get the MSD with a limiter, #6AL both work great. Get it hidden and leave the original on the hood with the wiring, so it looks like it is still running of the old "buzz" box.
  7. Steve Magnusson
    26,785
    #7 Steve Magnusson, Sep 18, 2008
    What about the triggering mechanism for using the MSD -- does it need to be changed to something else?
    I can't recall the 512BB/BBi people saying that they needed to change to something else, but the stock arrangement is just a variable relutance coil -- is that a sufficient thing to trigger the MSD units?
    Shawn -- You should also check with T. Rutlands -- seems like a nice "undetectable" improved replacement (found this while trying to see what the BB/BBi guys use for a triggering mechanism with the MSD units -- which I still like to hear about from the BB/BBi guys):
    http://www.permatune.com/ignition-Ferrari-aec-103b.html
  8. Fritz Ficke
    Fritz Ficke Formula 3
    2,266
    Tucson, AZ.
    Fritz Ficke
    The factory dist. "triggers" the MSD fine.
  9. Shawn Miller
    Shawn Miller Rookie
    Apr 16, 2008
    14
    Indianapolis
    Yes I did mean the ignition unit not computer. My mechanic thinks he can repair the original, if not we will go with the MSD most likely. Will let you know how this turns out. Cant wait to get the car running well, havent been able to drive it very much since I got it.
  10. dstacy
    dstacy F1 World Champ
    11,998
    GMT -5 & GMT +1
    Dave
    Perma tune will rebuild it for you for around a grand.
  11. 400iGuy
    400iGuy Formula 3
    1,077
    Central Florida
    Al
    There is no computer. If your mechanic has found one please post photos!
    Al
  12. Steve Magnusson
    26,785
    Thanks for confirming that Fritz -- and I probably could've assumed that it did; otherwise, we would've had a lot more discussion about it here ;)
  13. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Isn't that the function of the brain? Have noticed that most seem to have the add'l small box.
    Have these things always buzzed since day 1 or is it a warning of things to come?
  14. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
  15. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
  16. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    My 1980 400i #28903 has had an MSD 6A for 10 or 12 years now..aside from the very unsanitary looking installation by the previous owner in Dallas..it has funtioned flawlessly..and for under $200 smackers..why would even consider anyting else..it is Bulletproof...hope this is of some value..Jacques...get the red MSD Blaster 2 coil also... they are made for each other..hope this helps..Jacques.
  17. 400iGuy
    400iGuy Formula 3
    1,077
    Central Florida
    Al
    #17 400iGuy, Sep 19, 2008
    for how much $$?
    I used the MSD 6 Offroad 6470. The difference between the Offroad and other MSD 6 are:
    1. it's black (you can accomplish the same with a spray can).
    2. It's water proof and shock proof.
    Both were positives in my case. The box is hidden behind the grill next to the radiator (for those familiar with the 400i it's just below and forward of the Dinoplex). Black is good because it is almost impossible to see and since this is an area exposed to the elements the water proofing is good too.
    The Dinoplex is unmolested in it's original position connected to it's original harness. It just no longer makes those weird noises!
    The improvement was huge.
    MSD 6 Offroad info => http://www.msdignition.com/ignition_8_6470.htm
    Installation instructions http://www.msdignition.com/pdf/6470_frm22699.pdf
    Al
  18. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Funny you should mention that, tried to find out that very same thing but none of the 10 US suppliers seem to list that or the variety of Permatune products on their sites. In some instances, that throws a flag.
  19. Roadtripguy
    Roadtripguy Karting
    Nov 26, 2007
    53
    Hi...
    I too am looking to do this MSD 6A mod to my '83 400i. I'm on my second dinoplex, and I just don't trust these things for long trips since the car STOPS when they break (found that out!).
    A question:
    The 6A specs say that it will work for a 4, 6 or 8 cyl. engine. How did you guys make it work? I'm ASSUMING that you set it up for a 6 cyl. and it "just works," but I'd like to confirm this.
    Any other set up tips? Any tachometer problems afterwards?
    Thanks!
    Gerry
  20. jacques
    May 23, 2006
    877
    Los Angeles/Florida
    I was told by MSD that since there is only one distributor ..only one MSD is needed...2 distributors..2 needed..makes sense to me since the single dizzy has only one connection for both banks..whereas the twin dizzy set-up has one connection for each bank..thus the need for 2 MSD units..IT WORKS...so plug it in and drive it..I'll bet that this thread lasts until at least next June..(LOL)..hope this is of some value..Jacques
  21. Roadtripguy
    Roadtripguy Karting
    Nov 26, 2007
    53
    Thanks, Jacques, but I know that only one unit is needed. My question is which setting is the unit on? According to the spec sheet, the 6A will work for 4, 6, and 8 cylinder engines, depending on if a jumper wire(s) is(are) snipped or not. I can figure this out by trial and error, but would rather have an answer from someone who's done this mod before. That way, I won't have to have to possibly repair a jumper I snipped in error.
    Thanks,
    Gerry
  22. Fritz Ficke
    2,266
    Tucson, AZ.
    Fritz Ficke
    I called MSD Tech. support and asked what I should use on my 12 cylinder 400I and they said "6A" So I brought one for $180.00, follwed the instructions, and in one hour had it installed in the same place on the hood. I took the stickers off and I think I will paint it black. I have put over 9,000 miles on it in this car and many more on one in another car. I have not heard of them failing and feel more comfortable than with the old M. M. unit. It is just a good after market C. D. box nothing more and nothing less.
  23. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    I'm curious if the second box is OEM/NOS or a Permatune rebuild.
  24. Roadtripguy
    Roadtripguy Karting
    Nov 26, 2007
    53
    First buzz box (that failed) was original to the car. The second unit was NOS, and originally a spare for a BB LM race car (without the rev limiter, obviously).
    Gerry
  25. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Well, for the record, I'm on my 2nd one...1st one replaced @ 12k mi., 2nd one has 14k mi. & still buzzin' strong.
