Only Ferrari Will Be Running KERS @ Silverstone | FerrariChat
Discussion in 'F1' started by Remy Zero, Jun 20, 2009.
  1. Remy Zero
    Remy Zero Two Time F1 World Champ
    Apr 26, 2005
    23,476
    KL, Malaysia
    MC Cool Breeze
    Only one team will be running Kers in SIlverstone. And that system took about 50 mil dollars to develop. Thanks Max. What were u sayin about cost cutting again?
    For the first time in 2009, neither McLaren will feature a KERS system in qualifying and the race at Silverstone.
    The British team experimented during Friday's practice sessions by not using the energy recovery system on the car driven by Lewis Hamilton.
    McLaren confirmed that the "benefits of using KERS are less pronounced" at the circuit, and on Saturday morning removed the system on Heikki Kovalainen's MP4-24.
    Click here to find out more!
    Mercedes' Norbert Haug said: "Silverstone is a circuit where you do not brake too often: you get less of a benefit from the system here than you would on heavy-braking circuits."
    The decision means the only KERS-equipped cars at Silverstone are the two Ferraris.
  2. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    *Hopefully* that's because they feel they've got the weight distribution right, even with it installed. Even FM said it's of "questionable" use around S/Stone.
    We'll see at upcoming races I guess. If only the rules allowed 'em to use it "properly" - Apparently, they could get ~160HP out of it.
    Cheers,
    Ian
    BTW - The expense of developing it is just another confirmation that MM has lost the plot.
  3. Remy Zero
    Apr 26, 2005
    23,476
    KL, Malaysia
    MC Cool Breeze
    Ferrari has siad in the past (Monaco i think) that the F60 is desinged to run with the KERS, and not without, as it affects the weight distribution...
  4. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Yep, understood. But, they've certainly been going back and forth with it until now.....
  5. Remy Zero
    Apr 26, 2005
    23,476
    KL, Malaysia
    MC Cool Breeze
    +1
    i was surprised to see how Massa struggled with the new chassis.
  6. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    It's probably the most consequently designed KERS car in the grid, especially in terms of weight balance. Remember my thread about the "lecture" by an F1 engineer I recently attended? He said that Ferrari relied heavily on the batteries being in the front wing, which had most probably made them the fastest car in the grid if FIA hadn't outruled it.
  7. patricko
    patricko Formula Junior
    Aug 30, 2005
    532
    Huntington Beach, CA
    Patrick O'Neill
    That sounds very dangerous. Can you imagine the front wing flying into the packed grandstands carried by the momentum of the batteries?
  8. vinuneuro
    vinuneuro F1 Rookie
    May 6, 2007
    2,574
    Chicago
    Vig
    Yes, but they're on a new chassis now.
  9. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    That wasn't the problem afaik. It was outruled because of the possibility that the driver could be exposed to fumes in case of leaking batteries.
  10. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    #10 Fast_ian, Jun 20, 2009
    Like happened to Kimi when they exploded under his legs (!) and the magic smoke came out of his cockpit a while back?........ (China?)
    I *thought* it was potential danger to marshalls more than spectators, but don't know.
    Gotta think that much weight way up there changes your engineering though..... [2nd polar moments, anyone? ;)]
    If really true I'm surprised they're not in the same **** as Mclaren! How the mighty fall - 19th!
    Cheers,
    Ian
  11. vinuneuro
    vinuneuro F1 Rookie
    May 6, 2007
    2,574
    Chicago
    Vig
    I believe that was the halon from the fire suppression system as noted by Martin Brundle, not an actual fire.
  12. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Err - I don't *believe* so - IIRC Windsor was going on (and on!) about the foul smell it was emitting [For quite a while apparently].
    That ain't halon :)
    Cheers,
    Ian
  13. kraftwerk
    kraftwerk Two Time F1 World Champ
    May 12, 2007
    26,826
    England North West
    Steve
    I'm a bit more cynical with this, if true Ferrari fastest car with batterys up front and then gets knocked back with the diffuser issue.
    That was the straw that broke the camels back, Luca then decided he wanted shut of Porno Max.
  14. LightGuy
    LightGuy Four Time F1 World Champ
    45,931
    Texas
    David
    #14 LightGuy, Jun 20, 2009
    There has got to more to the KERS problem than meets the eye.
    I dont buy the "weight distribution" argument fully. Not to the point that it is not worth an extra 80 HP for 6 seconds twice a lap. And its not just HP. Electric motors are known to produce instant immediate Torque. The old expression "Horse power sells engines, Torque wins races".
    Its not like its an additional weight.
    Perhaps the rotational mass of the generator is permanently fixed to the crankshaft creating an inertial drag everywhere.
  15. Modena360-66
    Modena360-66 Formula Junior
    Sep 25, 2007
    873
    Perpignan, France
    Nathan
    Whatever is the problem, obviously that kers thing isn't working.
    They spent a fortune developing that cr*ppy device that no one uses,
    shows you how Max and is crew are out of they mind and doesn't know what they are talking about, reducing costs ?
    what a joke !
  16. vinuneuro
    vinuneuro F1 Rookie
    May 6, 2007
    2,574
    Chicago
    Vig
    That's one of the first things Brundle commented on (from the commentary box); about how terrible that stuff smells.
  17. Forexpreneur
    Forexpreneur Formula Junior
    May 11, 2009
    638
    Portland, OR
    Alexander Everhart
    #17 Forexpreneur, Jun 21, 2009
    I think KERS is similar to Obama's health plan. Very expensive but they'll make the rich pay for it in order to cut costs for the poor. :)
