Open Trailer Towing | FerrariChat
Open Trailer Towing
Discussion in 'Ferrari Discussion (not model specific)' started by Kent Adams, Dec 22, 2021.
  1. Kent Adams
    Kent Adams F1 Rookie
    3,086
    I recently purchased an Aluma open tilt trailer. I have never driven a car onto a trailer or towed a car before. I have hooked up the electronic brakes, brake controller etc.
    Here is my question. Should I buy a winch to load the car rather than drive it onto the trailer? There must be an advantage for winching a car up on a trailer rather than driving it onto the trailer. I'm all new to this so all opinions are welcome!
    Thanks in advance.
  2. technom3
    technom3 F1 World Champ
    18,209
    Phoenix AZ
    Justin
    What car are you loading and what transmission.
    If it's an F1 car and it's your first time loading a car... I'd probably winch it.
    If it is a stick or dct. Drive it on.
    Just have people watching and spotting. Have a plan. It's stressful. Don't yell. Be clear with what you want or don't want to happen.
    Take your time.
    Make sure you balance the weight on the trailer. Do not give it all tongue weight.
    Most of all... If you have a friend who had done it before... Ask him to come help you.
    Also where are you? Maybe a forum member can help? If your in my area I'd be happy to assist.
    Il Tifoso and Texas Forever like this.
  3. Kent Adams
    3,086
    I'm loading an F430 stick but will likely have to do it alone and by myself with no one around. :(
    Texas Forever likes this.
  4. Texas Forever
    Texas Forever Eight Time F1 World Champ
    BANNED Rossa Subscribed
    Apr 28, 2003
    85,600
    Texas!
    The biggest problem will be ground clearance. Most trailers are too low. Be prepared with wooden shims.
    technom3 likes this.
  5. technom3
    18,209
    Phoenix AZ
    Justin
    Bring wood and if this is going to be a more than once thing..m buy some race ramps. Worth their weight in gold in these situations.
    As another thing if you can get the trailer say in the street and the ramps extended into the parking lot or drive way you can get some height out of that to ensure your approach angle is less.
    Triple check everything. Take your time. Make sure you have the correct ball on your hitch. Triple check. Make sure it's right. It's always worth it.
    How long are your ramps?
  6. Texas Forever
    Apr 28, 2003
    85,600
    Texas!
    And triple check your tie downs again. Don't ask me why this is a good idea.
    Shorn355 and technom3 like this.
  7. Cotton
    Cotton Formula Junior
    Dec 11, 2008
    391
    TN
    Buy a winch with a wireless remote. I load solo all the time and have for years. With a winch and wireless remote you can walk all around the vehicle while you’re loading and have much better control. I have this setup in my open and enclosed trailers.
    If you zoom in on the picture you can see the winch and battery box in the front.
  8. technom3
    18,209
    Phoenix AZ
    Justin
    Beautiful set up.
    Shorn355 likes this.
  9. technom3
    18,209
    Phoenix AZ
    Justin
    And if it's a convertible make sure the top is latched... Don't ask me how I know...
  10. fatbillybob
    Aug 10, 2002
    28,709
    socal
    Right answer! There is no other. Life is about doing stuff but reducing risk.
    Trailer
    lumber
    wireless winch
    4 real tiedowns at 4 corners no crossing
    2 metal wheel chocks (the more expensive the car the more you want wheel chocks placed fore and aft of 1 tire)
    2 bungie cords for each side of chocks and a retaining strap or chain for the chocks.
    tow out of gear/E brake on
    If you a 1st timer watch driver's door when you open it will hit trailer fender.
    BoulderFCar and Kent Adams like this.
  11. simon klein
    simon klein Two Time F1 World Champ
    Feb 25, 2009
    29,709
    North Qld
    simon klein
    I'm surprised this hasn't been mentioned:
    Front engined car put on forward.
    Rear/mid engine car put on rearwards..unless you have Cottons setup which allows the R/M car to go on forwards.
    As you've said it's an open trailer and a 430 I suggest you cover,VERY very well, the rear screen with heavy duty cardboard or the like!...1 Aussie didn't on his 355 and paid the,expensive,price.
    19633500GT likes this.
  12. Kent Adams
    3,086
    #12 Kent Adams, Dec 23, 2021
    There aren't any ramps on this trailer, its a tilt trailer like the picture attached. My trailer has the air dam up front. the fenders come off the trailer for loading and unloading. If the approach angle is too much, I have some race ramps I can use.
    INRange likes this.
  13. technom3
    18,209
    Phoenix AZ
    Justin
    Putting a mid engine Ferrari on backwards in unnessecary. They are balanced enough to make this not a concern.
    More important is where you place the load on the trailer and that is over the axles vs behind the axles vs all tongue weight.
    Balancing the trailer by positioning the car more forward or rear is more important than placing it backwards on the trailer.
  14. technom3
    18,209
    Phoenix AZ
    Justin
    You'll be just fine!
    Kent Adams likes this.
  15. henryr
    henryr Two Time F1 World Champ
    22,358
    Atlanta
    Juan Sánchez Villa-L
    you'll start with the winching and then just drive it up later when u get comfortable doing it. i can drive mine right up just looking out the drivers side as i know exactly how the car needs to be positioned
  16. Dave Bertrand
    Dave Bertrand Formula Junior
    823
    Castle Rock, CO
    The winch cable will be at an angle, so how do you winch the car up without damaging the bumper? Remove the bumper first? Or is there a tow hook that mounts in the bumper?
  17. henryr
    22,358
    Atlanta
    u have the tow hook that screws into the front?
  18. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,391
    Santa Clarita, CA
    The best part about winching is that it can be done very slowly and you can walk around the car and trailer and look at everything during the process. If you are driving it on yourself, you won’t be able to do that. Definitely use Race Ramps. Harbor Freight has some great winches that are inexpensive. I use one to winch my formula car onto an open trailer.
  19. Dave Bertrand
    823
    Castle Rock, CO
    No, I have a 328 where the tow hook is under the car. Obviously not relevant to this thread though, since I would guess the more modern cars have tow hooks that screw into the front bumper.
  20. Kent Adams
    3,086
    This is the winch I had in mind: https://www.etrailer.com/Electric-Winch/ComeUp/CU645010.html
  21. technom3
    18,209
    Phoenix AZ
    Justin
    Just be careful onna tilt trailer because if your not in it and it tilts............
    Carbon Bits likes this.
  22. Kent Adams
    3,086
    Ok, this got my attention. Can you elaborate? Is this from personal experience or something you've seen?
  23. technom3
    18,209
    Phoenix AZ
    Justin
    Just if you are not in the car and the bed tilts down. The car will roll forward due to the inertia. You need to have the brake on or be in it when the trailer tilts forward/level again or else the car is going to drive/roll into the stone guard by itself.
  24. Kent Adams
    3,086
    Aww....I see, that does make a lot of sense to me. I hadn't thought of that. Perhaps a simple board across the bed of the trailer would halt any forward momentum and the winch would stop any back momentum. I would think it would stop with a simple 2x4?
  25. fatbillybob
    Aug 10, 2002
    28,709
    socal
    use ferrari screw in tow eye. That's what is is for
