Opinions on "Stuck Accellerator" | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by vrsurgeon, Sep 5, 2012.
  1. vrsurgeon
    vrsurgeon F1 World Champ
    16,527
    Charleston, SC
    Curt
    Sorry if already discussed but... Driving to work today I was thinking about all these "stuck accellerator" pedals. It seems your average driver is THAT bad....
    Protocol for stuck accellerator
    1) Panic
    2) call *HP
    3) barrel down highway until HP stops you, roll car or run out of gas
    Why not just shift into neutral and if that isn't possible wait for a straight away and turn off ignition (but don't pull out key) and stand on brake pedal? I don't get it and I don't buy it.
    Protocol for "unintended accelleration" in my 360
    1) Smile and enjoy
  2. Steve Magnusson
    26,785
    +1 -- they should get a ticket for not knowing how to operate a motor vehicle ;)
  3. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,714
    ESP
    Bas
    A friend of mine had his accelerator become stuck whilst bashing around on some b roads in the UK. He was in his 200sx (240sx for the 'Mericans), car was fairly highly modified with a big ass turbo and 2 bar of boost. He came onto a straight and only realised his throttle was stuck when he had to brake for a sharp 90 degree turn.
    It all happened too fast and didn't think of turning of the engine or using his clutch; car went through a metal gate, jumped over a river and came to rest a few hundred meters in.
    He was shaken and his chassis bent upwards (banana style). Luckily chassis are cheap in the UK so he bought one for £500 and spend a weekend throwing parts over.
    But in general, I don't buy it either. The whole prius situation a while ago where just people laughing their way to a law suit. A prius could never get up to serious speed :p ;).
  4. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    You're right that step one is panic. At that point it seems you can't count on anyone taking the reasonable steps, nor possibly even being able to do simple things when instructed. At least with many people.
    I saw a guy at an autocross some years ago blast down half a mile of runway before hitting some objects at the end without shifting the automatic into neutral. That should have been a more relaxed atmosphere to assess the situation without worrying about other cars, etc but didn't happen.
    I'm incredulous that her car was such a POS that the accelerator stuck, the transmission wouldn't shift into neutral and the engine wouldn't shut off all at the same time! I think the 911 operator needed to work to calm her down and get someone to google the type of car she was driving and see what kind of shifter it had and talk her slowly into getting it into neutral. Of course, I haven't listened to the whole half hour tape, maybe that wasn't effective, either.
  5. speed racer
    speed racer Formula 3
    Feb 16, 2008
    1,462
    Burr Ridge IL.
    PJ
    Back in the 90's I owned a 911Targa. I,m driving straight thru from Michigan to Florida. Just outside Talahasee about 2AM. I slowly hit the brakes as I'm approaching a set of toll booths with cement abuttments seperating each one. But my cruise control will not disengage and my foot goes to the floor. So I'm traveling at about 85 mph living on coffee and twinkies for about 18hrs. Its 2 am and I have no brakes. I pick a toll booth that does not have its wood barrier down and no cars in front of it and thread the needle..Once I'm thru it occurs to me to just shut the car off.....Which i promptly did and when I had recovered from my possible near death experience. I restarted the car which drove normally without the use of cruise control. When i eventually got back home I took the car to the dealer and related my experience. Officially, i was told tht an air bubble may have gotten inside the brake line causing the brakes to malfunction. Unofficially, the look on the service managers face told mr that this wasn,t the first time he had heard a story like mine. All i know is that i never used the cruise control again as long as i owned the car. More importantly, cruise control was unavaiable the next couple of years on newer 911's
  6. Redneck Slim
    Redneck Slim Formula 3
    Mar 10, 2011
    1,651
    Palo Alto,CA,USA
    Walt Kimball
    Claims of unintended acceleration did a lot of harm to Toyota recently and to Audi back in the 1980s. In both cases,the problem turned out to be driver error.
  7. hotsauce
    hotsauce Formula Junior
    Jan 23, 2011
    682
    around
    [ame]http://www.youtube.com/watch?v=4TqhBatmvxY[/ame]
    I think we need a video of some one shift into reverse, for added breaking of course.
  8. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    I was curious about all the reports. And I haven't done this with a very high powered car but for curiosity purposes I took a Prius and a Camry. Going about 75 mph on the highway I planted my foot on the accelerator then eased my other foot on the brake applying more pressure steadily. On both cars the brakes easily overpowered the engine. Easily. I suggest people try it themselves.
    I had a throttle spring brake years ago on my motorcycle so it was stuck wide open. There was a moment of panic, but then I just got onto the brakes,was able to overpower the engine, the rpms were drug down and I killed the engine when I was down to about 15 mph. It's never a fun experience. Given a highway circumstance I think the first suggestion would be to take all feet off pedals to make sure the throttle is indeed stuck. On my M/C the second instinct was to push in the clutch and that caused the engine to rev too high so I let clutch back out and did as below.
  9. SCousineau
    SCousineau Guest
    Jul 17, 2004
    3,652
    S Cousineau
    I have experienced pedals getting stuck by loose floor mats, other crap tossed about in the car, and really frayed cables in my life. I watched a driver in a car I was passenger in press the gas pedal harder and harder wondering why it would not stop. I reached over and turned the key off to save my own neck in addition to theirs. Being young at that time we both laughed.
    In each of those cases there is a logical explanation and a solution such as better maintenance, anchoring things, or turning off the key.
    There are probably stories that fit what the media presents out there, but they have to be rare. Driving a car is complex in some situations. I suspect confusion is the explanation in most cases--but being open minded facts of the specifics could lead to other explanations.
    -sc
  10. vrsurgeon
    16,527
    Charleston, SC
    Curt
    I think most cases involve the above... that and the confusion that comes with panic. It just astounds me that people wouldn't think to turn off the key or switch into neutral.
    I'd argue that licenses should be suspended for being so ridiculously incompetent behind the wheel.. but since 90% of people behind the wheel are zombies, this would empty the roads and DMVs would loose all their revenue.
    As an aside, when society dictates that someone else should do all the thinking for you.. it really dulls decision making ability. Thus, America as it is. :(
  11. werewolf
    werewolf F1 World Champ
    11,022
    goodbye
    It's bogus.
    My oldest friend has worked at Chrysler for ~25 years, started in the brake department. He told me something, and then demonstrated it for me: put your car in first gear, for maximum torque at the wheels. Floor the accelerator. Then stand on the brake. Which one wins?
    The answer as i understand it, and have experienced it: Brakes win. Always.
    So ... anyone claiming that the accelerator stuck, and the brakes didn't stop the car, is claiming that two, independent systems on the car failed at the same time. The odds of this are ridiculously low. So i don't buy it.
    This, in addition to everything else that's been stated about shutting off the car, putting it in neutral, etc etc
  12. JWeiss
    JWeiss F1 World Champ
    Nov 18, 2010
    12,183
    NYC and Long Island, NY
    JWeiss
    Finally found you. Please send a check for $0.75 immediately to the Florida Toll Authority. Don't forget the 20 years of interest, too. Thanks for driving the Florida Highways!
  13. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
    This is my favorite instructional video ever.
    Warning, for watching at work: Lots and lots of F'words!
    [ame]http://www.youtube.com/watch?v=lZ4PtafRB9c[/ame]
  14. Scuderia_Ferrari
    Scuderia_Ferrari Formula Junior
    Sep 13, 2004
    749
    Ottawa, Canada
    Jamie
    "Hello YouTube. If you've clicked on this link, it must mean you're a f**king retard!"
    Funniest thing I'v seen all week. Sadly though, many people actually don't know the first thing about how cars work these days. I'm 22 and I know SEVERAL people (not to sound sexist, but mostly woman) that have no clue what "neutral" is to begin with.
  15. Bas
    Mar 24, 2008
    42,714
    ESP
    Bas
    Happen to a friend of mine last year on his gas gas during an offroad race. Instead of turning the bike off, holding in the clutch or just brake....he flung himself of the bike. He got a lot of stick for that one....haha!
