Optima red top 34R battery NOT recommended | FerrariChat
Discussion in '360/430' started by f355spider, Dec 28, 2019.
  1. f355spider
    f355spider F1 World Champ
    18,029
    Optima red top used to be awesome years ago, but no longer. Often a single deep discharge will kill it, and many times they suffer short life. Red top is oem installed in 430 Scuderias and 16Ms. Ferrari even uses a special battery tray that is a custom fit for the Optima red top. To use something else requires replacing the battery tray with one from a regular F430 at a cost of several hundred dollars of course.
    My 430 Scuderia is on its second red top, from reviewing records, and is about 6 years old and was testing as borderline failing. I ordered another red top, as I didn't want to mess with replacing the battery tray. While removing the old red top, what do I find? Its freaking leaking! (appears to be venting out the two black foam things on the top) Something obviously was failing to cause it to leak out the vents. Another reason red top sucks. I cleaned up the battery tray best I could with some baking soda, but it is permanently etched. Fortunately it did not migrate below the tray onto the chassis or frame. Being a glutton for punishment, I went ahead and installed the new red top I ordered recently online.
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,396
    San Carlos, CA
    Mitchell Le
    I don't buy it anymore. Just the Interstate one now.
    SoftwareDrone and f355spider like this.
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
  4. Sky Hye
    Sky Hye Formula Junior
    710
    SoCal
    So no red top. What’s an alternative? I see interstate up top. Is there a model number?
  5. f355spider
    18,029
    #5 f355spider, Dec 29, 2019
    Interstate, I believe the group 48 AGM fits better than the 34R (there is a thread on Fchat discussing that a regular 34R battery is a tight fit). Note that the Optima red top is rated at 800CCA and the Interstate group 48 is rated at 730 CCA. The Interstate group 34R is rated at 800CCA. The Interstate group 48 AGM is top rated by Consumer Reports recently.
    With either 34R or 48, you will need to replace the battery tray in a 430 Scuderia or 16M (if delivered in North America) to a standard F430 battery tray, as the Scuderia/16M version (for NA) is sized with cut outs to specifically fit the Optima. Looks like this is the part
    https://www.ricambiamerica.com/car-diagrams/ferrari/v6-v8/430-group/f430-05-08/battery/67943100-battery-bin.html
    vraa likes this.
  6. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Or if you go with an F430 tray, consider an H8 40Ah Antigravity lithium ion battery. Much lighter than a lead-acid/AGM battery at around 18 lbs., to a regular battery at 48 lbs. or more.
    Sky Hye likes this.
  7. INRange
    INRange F1 World Champ
    12,118
    Virginia/Florida/Caymans
    JD
    What battery tender do you use?
  8. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,790
    San Jose, California
    That is EXACTLY what I was going to say.
  9. Sky Hye
    710
    SoCal
    Can you use/charge it like a normal batt?
  10. vraa
    vraa F1 Rookie
    4,501
    Texas
    Mr. A
    As long as your charger supports lithium
    And you're cool with the price
    Need4Spd likes this.
  11. f355spider
    18,029
  12. f355spider
    18,029
    First few years a Granite Save a Battery, but been using that on my BMW now. The past couple years I have used the Griots Garage Battery Manager IV. Both are compatible with AGM, and the Griots actually has a specific charge setting for AGM that it defaults to, which means it is always on that setting when I plug it in.
  13. f355spider
    18,029
    Yes, but the battery tender used for a lithium has to be one of two types. Either specifically made for charging lithium, or a standard type microprocessor controlled battery tender. By standard, I mean one that does not have "anti sulfation" or other type special charge settings. It simply charges the battery then goes into a float mode, nothing else. No temperature compensation, etc. I believe the reason is lithium chemistry is more sensitive to the higher voltage applied by such things as temperature compensation, anti-sulfation and the like. If you read up on lithium car and motorcycle batteries, the manufacturers give warnings about this, and how to charge. I used to use a simple "wall wart" 1 amp microprocessor charger for my lithium motorcycle battery...but all the warnings scared me into simply purchasing a dedicated lithium specific "wall wart" charger from Deltran. ;) It's been five years now, and the battery still works well...though has lost some compacity when I load tested it recently. I usually only get two to four years max with a standard flooded cell battery on my motorcycle I have owned for 33 years. So the lithium is working out to be a good value for this application
  14. INRange
    12,118
    JD
    I agree that what you purchased should work for the AGM. What I am suggesting is that for whatever set of reasons.....the charger overcharged the battery and caused it to fail. I have seen this too many times on boats where the charger just cooks the AGM batteries and causes them to leak out the vents. The composition of Optima batteries is really no different than other AGM batteries. There are no electronics in them to prevent overcharge. What happened to one battery type can happen to another unless it is an internal cell failure. An internal cell failure can cause the charger to think it is undercharged which in turn will cook the battery.
  15. f355spider
    18,029
    Since all of my battery tenders are microprocessor controlled to prevent over charging, then yes, it is possible there was internal cell failure of the battery that caused the battery tender to over charge. Fine, further proves that Optima red top batteries suck. :)
  16. Rifledriver
    36,769
    The battery trays are easily made to fit conventional batteries. Done it a few times because for at least the last ten years I refuse to service, or install Optimas. To me they are only trade in material.
    f355spider likes this.
  17. driller1
    driller1 Karting
    125
    New Hampshire
    Scott
    I have used an Odyssey battery in several of my cars, including my 430. They are an AGM sealed battery, I have one that is 5 years old and has been fine.
    Just be sure to use a maintainer that recognizes AGM, as they require a slightly different charge cycle.
  18. tazandjan
    39,021
    Optima made good batteries in the olden days, but then Johnson Controls bought them and moved production to Mexico. Have not been worth a bucket of warm spit (to quote an old VP) since.
  19. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    904
    S La
    Which battery do you recommend? Forgot what the brand was but I got 7 years out of the last battery keeping it always connected to a Ctek.
  20. Rifledriver
    36,769
    Conventional name brand. Pick one.
    Gumart1 likes this.
  21. ItalGerBrit
    Mar 15, 2016
    904
    S La
    Got it. What ever fits makes sense. Thanks.
  22. ItalGerBrit
    Mar 15, 2016
    904
    S La
    So Optimas are the Range Rovers of batteries?
  23. Rifledriver
    36,769
    Good idea but just like the Chevy Vega, Johnson controls decided to make it cheap.
    The same aluminum treating process Mahle developed and made millions of pistons and liners that last a very long time Ferrari 4 valve motors from 83-95, Chevrolet bought the rights to and did on the cheap. They are still living down the Vega.
    Mahle has never since sold the rights to make it to anyone else.
  24. f355spider
    18,029
    Consumer Reports top rates the Interstate AGM batteries
  25. Rifledriver
    36,769
    If I lived by Consumer Report ratings my life would be full of bad decisions.
    INRange, KC360 FL, CarbonDan and 2 others like this.
