original GTSi muffler hinged access to insides? | Page 2 | FerrariChat
Discussion in '308/328' started by Du_Man, Jul 13, 2023.
  1. Imatk
    Imatk Formula Junior
    May 6, 2007
    811
    Now I want to try my hand at Zinc Plating![/QUOTE]
    I would check with Caswell if I were you.
    I tried doing it myself with homemade stuff but with the wrong chemistry it's a nightmare.
    I got the Caswell chems and everything works like it should. I'm plating pieces as I go which is nice since I don't have to remember where all the bolts and nuts and washers go would I to send them off somewhere.
  2. Du_Man
    Du_Man Formula Junior
    320
    Dallas, Texas
    Derek
    I got the Caswell chems and everything works like it should. I'm plating pieces as I go which is nice since I don't have to remember where all the bolts and nuts and washers go would I to send them off somewhere.[/QUOTE]
    I got all the Caswell chemicals.....just a matter of time!
    Imatk likes this.
  3. Du_Man
    320
    Dallas, Texas
    Derek
    #28 Du_Man, Feb 27, 2024
    Can I piggyback on this thread since it's exhaust-related?
    My exhaust header has a crack on one of the pipes.....3/4 of the way around and it seems the crack is more separated on the inaccessible side! To formulate my repair plan, do I need to know the specifics of the stainless steel (non-magnetic) used to make these headers?
    How would you approach this repair? Cut a large opening on the accessible side to access the opposite cracked side and weld it? Stainless steel MIG wire and pure Argon? My TIG skills are not good yet. I have read that some guys weld a patch over the troublesome repaired area to additionally help bridge and stop stress cracks from recurring. thank you!
