Original Spark Plug Wires | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by Vintageignition, Jun 11, 2024.
  1. Vintageignition
    Vintageignition Karting
    Dec 17, 2020
    53
    Mike Mancini
    Pertaining to a 1960 250 outside plug V12:
    I am trying to find out what the spark plug wires were that were originally installed by the factory.
    I am looking for details beyond 7MM black, solid core.
    I would like to find someone with a genuine original reference set to determine any brand or markings that may be on the wire itself as well as the style and brand markings/ID of the boots.
    Any help would be much appreciated.
  2. kare
    kare F1 Rookie
    Nov 11, 2003
    3,840
  3. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,038
    Kare is correct. Not all of the spark plug wires were black in this era.
  4. Vintageignition
    Dec 17, 2020
    53
    Mike Mancini
    Thank you for the information. I still would love to see an original set if anyone has them or access to some for reference questions.
  5. lancia
    lancia Formula Junior
    Jan 18, 2004
    575
    I recall seeing original inside-plug 250 orange rubber spark plug boots (straight) with raised fine marking 'Pirelli', molded in. Regrets, wish I still had that photo. I once asked a restorer where they found 7 mm gray solid core spark-plug wire. They simply used gray flexible vinyl paint to color Packard 440 wire. Here a photo of inside-plug 250 at the factory. Whether gray wires were also sometimes originally used with outside-plug, I have no knowledge. 'Standard' makes a straight orange silicone rubber spark-plug boot (SPP19) - a bit long, but can be shortened (again, this is inside-plug detail). I am not familiar with the original 250 outside-plug boot configuration, except that I have encountered that in the 2nd picture here, black bakelite. Similar used on 1960's Alfa Romeo? Many use the Bosch brown bakelite boot, though I do not expect this is original type. I stand corrected if there is better knowledge.
    swift53, John Vardanian and enio45 like this.
