News
Out of town need to solve this Problem : RPM VERY HIGH :(
Discussion in 'Technical Q&A' started by jnabulsi, Dec 18, 2009.
  1. jnabulsi
    jnabulsi Rookie
    Aug 29, 2009
    9
    Car: 2008 f430 spider f1- it has less than 2000 miles,
    Problem: I was driving and all of a sudden I started to feel the RPM keep going higher on its own- so I am just pressing the brakes. When I stoped the car and got it into Neutral the RPM almost hit 9-10 alone, so I stopped the car. It says CHECK OK, so no problem arises, plz any advice as I am out of town , away from my garage and I have to go back tomorrow morning.
  3. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    Sounds like a stuck throttle cable. Do they still have cables or are they drive by wire? Can you even get to that stuff? I haven't dug throught the covers. I've had a return spring break once causing this problem on other vehicles.
    If it was me I'd call F-car dealers to see if this is a known issue and something you can address where you are. Don't know how many will be open on Saturday but you can do a search and just call them in random places around the country. They have always been helpful to me.
  4. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    What city are you near, there may be an f-chatter nearby with a couple tools to assist.
  5. jnabulsi
    jnabulsi Rookie
    Aug 29, 2009
    9
    Hello Drik,
    I am actually a bit far away- I live in Egypt :) and the dealer is not open. So i have to try out myself
  6. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    Yes, you are a distance off. Good luck with it. You could also try posting the question under the 360/430 section, some may look there that won't look here.
  8. stephenofkanza
    stephenofkanza Formula Junior
    Mar 5, 2005
    542
    Kansas
    Stephen LeRoy Sherma
    In my 308 I had a similar problem casued by the floor mat.
    Wish you luck.
    Stephen
  9. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Most likely floor mats have slipped forward and are touching/pressing on throttle pedal.
    If not that throttle cable or if fly by wire system ecu/throttle pedal rheostat failure.
    If mats aren't the issue try rebooting ECU.
  10. five40iguy
    five40iguy Rookie
    Dec 3, 2009
    13
    Or maybe you have a massive air leak somewhere, any hissing or sucking noises?
  11. haith
    haith Rookie
    Jun 7, 2008
    47
    North Lincs, UK
    Jon
    430s are "fly-by-wire" rather than using a cable. If there isn't anything physically pressing your accelerator down (like a floor mat getting in the way) then it sounds like you have an electronic issue. It's most probably the accelerator potentiometer that is faulty. I'd be very cautious about driving the car until you have it seen to (you could end up losing control of the car). In my experience however when a throttle potentiometer fails, you can usually only go very slow, but it sounds like you have the exact opposite problem!
  13. beast
    beast F1 Veteran
    May 31, 2003
    8,965
    Lewisville, TX
    Rob Guess
    Another possible problem could be the idle air control valve is stuck wide open allowing too much air to pass around the main throttle plate. In neutral unloaded the engine can rev quite high with a little extra air flowing to it.
  14. Zupra
    Zupra F1 Rookie
    Mar 31, 2004
    3,649
    St Louis
    Chesney
    Not to hijack the thread(Hope you get it fixed man), but I have an 87 CRX which has just about the same problem, when it's cold it will idle at sometimes around 3000+ RPM for 3-4 minutes, is this something I should be worried about?
  15. CAS
    CAS F1 Rookie
    Nov 6, 2003
    2,614
    San Diego, CA
    Clint
    No that's just a high idle so it warms up faster when cold. Try quickly blipping the throttle while the car is in neutral if you want it to kick down.
  16. Zupra
    Zupra F1 Rookie
    Mar 31, 2004
    3,649
    St Louis
    Chesney
    Yeah I try that but sometimes it just kicks it up a notch; at least I know it's not a bad thing. Only bad part is it's pretty much straight exhaust and annoys the neighbors in the morning.
  17. Jamie H
    Jamie H Formula 3
    Rossa Subscribed Owner
    Aug 28, 2009
    2,328
    Puslinch,ON
    Jamie
    I would disconnect one of the battery terminals for 1 minute then reconnect, although that may cause another issue. The issue that it may cause is the throttle actuator may have to be put through a 're-learn' procedure, worst case scenario is that the engine will start and idle but the throttle will not respond to driver input from the throttle pedal. In any case idle speed is much safer overall for your drivetrain. Otherwise get it on a flatbed tow truck and back to a dealer. Good Luck.
    Zupra - pm me about your car and I will give some things to check.
  18. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,267
    Cape Town, South Afr
    Jack Verschuur
    No knowledge on the 430 system whatsoever, but can you physically check the throttle position with the engine not running but contact on?
    I'd look for a disconnect of the throttle pot meter from the pedal (if this is possible), a stuck throttle plate/mechanism or a massive airleak (a larger hos came off)
  19. hotrod406
    hotrod406 Formula Junior
    Sep 18, 2007
    540
    Grand rapids area,MI
    Tim
    I'd be surprised if it wasn't a floor mat. There have to be multiple safeties for throttle problems so this doesn't happen. GM cars go into a limp mode when the commanded throttle opening does not match the actual. Pretty big liability for something like this to happen, it could kill people.
  20. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,267
    Jack Verschuur
    So, what happened?
