Outlaw 308 | Page 14 | FerrariChat
Outlaw 308
Discussion in '308/328' started by Vonbarron, Jul 20, 2019.
  1. david
    david Formula Junior
    Feb 21, 2001
    809
    Northwest
    david
    Is it OK to mix marine grade with aviation grade parts?
  2. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    As I’m now underwater with this project, I’m ready to fly like an eagle, into the sky
    Saabguy, david, bernieb and 1 other person like this.
  3. Jonny Law
    Jonny Law F1 Rookie
    3,203
    Over yonder.
    IT Guy
    Do most projects that involve a vintage Ferrari at some point get to, "I’m now underwater with this project"? :)
    Cirorsi and absostone like this.
  4. david
    Feb 21, 2001
    809
    Northwest
    david
    I believe they start underwater. ;)
    Saabguy likes this.
  5. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    I’m probably just being whiny, I think I’m at 27-28k total which is outrageous. In a year or so it should be a total dude magnet, like all Ferraris
    Jdubbya, Brian Harper and rjlloyd like this.
  6. Jdubbya
    Jdubbya The $10 Trillion Man
    43,209
    PNW
    Dudes and teenage boys seemed to be the ones always attracted to my old 308. :)
    It's coming along. Does it run already?
  7. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    LOL. Yeah if you are looking for a chick magnet probably best to buy a puppy.
    Rifledriver, Jdubbya and Cirorsi like this.
  8. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    SmokyDave likes this.
  9. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
  10. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    So I’ve been assembling the car as much as possible to get it squared away for where everything goes, miles of welding to do still, but today I was sticking cv joints in and noticed what the hell, these are used Ferrari shafts, someone siliconed way to small way to short and not anything any psycho would reasonably do, 4 out of 6 were done this way, at one time it was driving somewhere
  11. absostone
    absostone F1 World Champ
    10,036
    :eek:At least it’s the correct thread pitch
    SmokyDave and steved033 like this.
  12. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
  13. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    You sound like you speak from experience.
    Can you recommend a particular breed? Long or short hair? Is there a service that will allow puppy rental?
  14. GT4:13432
    GT4:13432 Rookie
    Feb 20, 2020
    38
    Australia
    Dave
    Quick question a bit off topic… to replace that gearbox linkage boot that you’ve shown (engine side one), you obviously need to remove that rod end that’s secured by the pin. Do you simply knock the pin out, pull the linkage off, put the rod end back on and knock the pin back in? Do you need to replace the pin? What holds the pin in place, just friction fit? Thanks.
  15. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    Yeah it’s just a spring steel pin, ol’ in N OUT
  16. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    From memory (which is not good) I think a new rubber boot can stretch over (old one may be too hard and break.)
  17. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,339
    Dumpster Fire #31
    SMG
    No, the rubber boot can slip over the bushing end. Only the really early series has the bushing secured with a roll pin, it was superceded to a one piece shaft where the bushing end does not come off. Technically the correct procedure is, you'd pull the shaft, replace the seals and slip the new boot on.
  18. GT4:13432
    GT4:13432 Rookie
    Feb 20, 2020
    38
    Australia
    Dave
    Ok will give that a go first. Doesn’t look like it would fit over the bush but maybe it’s stretchier than it looks o_O
  19. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Lube it up and warm it up with a heat gun on low or hair dryer.
    ChevyDave likes this.
  20. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,339
    Dumpster Fire #31
    SMG
    I'm going to disagree with the lube part, you really want that boot dry. Once oily it's going to attract dirt and grit, that dirt and grit then finds it's way into the seal... The purpose of the boot is to keep the shaft clean of road dirt and debris so that seal doesn't become damaged earlier then it's life cycle.
    If the boot is shot, imagine the condition of the seals... Hence the proper procedure of replacing seals and boot at the same time.
    Oil change, engine and gearbox, new seals, gaskets and if needed great time to adjust clutch and shift linkage.
  21. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    Tell them the fun part of adjusting the shifter after you put the shaft in! So fun
  22. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,339
    Dumpster Fire #31
    SMG
    Shhhh.... Don't spoil the adventure:D
  23. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    The lube is to get it off and then on. Easy to clean it once back on
  24. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    Had some time today to play muffler shop, chopped up some 2” stainless tubing to get the pipes around where they might go, sorted out the general location, played with some shapes but I’m still waiting for the stainless tapered mufflers to ship in to do final go, similar to Supertrapp
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    thoke and smg2 like this.
  25. absostone
    10,036
    Looks good . but on the right side long tube,, it should have a bend under the the axle IIRC?
