Outlaw 308 | Page 15 | FerrariChat
Outlaw 308
Discussion in '308/328' started by Vonbarron, Jul 20, 2019.
  1. absostone
    absostone F1 World Champ
    10,039
    And what is that U shape loop on your control arm?
  2. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    Needs a bend on the right side for regular folks but this is lowered an inch so no interference issues, the small loop on control arm is for 328 emergency brake cable hold down
    absostone likes this.
  3. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    great work, am i to assume you will be utilizing a true dual exhaust? I did the same with my euro GTS, the sound is incredible,i used 2 magnaflows
  4. Arvid
    Arvid Formula Junior
    May 28, 2012
    668
    Norway
    Arvid Andersson
    Care to share which type of Magnaflow mufflers ? Thinking on upgrading the sound so would be good to know.
  5. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    i cant recall, its been over 20 years, but be advised, this configuration of mufflers only works on the euro model, as i have a very shallow trunk area, so the mufflers tuck up under the car nicely, hence the need for a diaper on non euro cars.
  6. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    Yes will be duals, not equal length but I might do a balance pipe, probably won’t but the option is there
    cavallo_nero likes this.
  7. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
  8. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    Had a few minutes today, starting to figure out where the Electramotive ignition is going, I don’t have a back window so I was going to do a solid aluminum panel back there with a mail slot window so maybe I stick the coils back there, no idea, someone should stop me, was going to stick with rest on the bulkhead between the seats like it’s a flux capacitor, That’s pretty much it for wiring on the entire car, will just have headlights and tail lights and that’s it, oh and a fan, gotta have a fan
  9. BillyD
    BillyD Formula 3
    1,829
    Pacific Northwest
    Bill
    You're going to drive it on the road? In Washington? On I5 with the no sense of humor Washington State Patrol?
    Please rehearse "Yes officer" in your most unthreatening voice.
  10. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    Jack-the-lad, derekw, smg2 and 2 others like this.
  11. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,150
    SanFrancisco BayArea
    1983 US 308 GTS QV
    Is it possible to bend plexiglass around a buck?
  12. Jonny Law
    Jonny Law F1 Rookie
    3,203
    Over yonder.
    IT Guy
  13. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    Yes, I’ve done lexan windshields and polycarbonate, thought about doing red but will most likely use aluminum
  14. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    Should be plug and play as it was already tuned and driving
  15. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
  16. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,339
    Dumpster Fire #31
    SMG
    HMmmmm... If you can I'd suggest turning/rotating it so that the top and bottom tanks sit horizontal, bottom supply feed no lower then output port on the block. Tilt it all you want, but running tilted like it is has not just cooling issues but the drain back to the sump isn't going to happen. That's just my nitpicky opinion:p
  17. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    I was wondering about the drain action, I’m hoping there’s enough gravity drop
  18. absostone
    10,039
    dont forget 80 psi will help circulate. Also the cooler hoses are big, but still better to have the cooler up higher .
  19. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    It’s watering day, since I have to make Everything anyway I might as well do the cooling system, I went with Stainless since that’s what I have, rolled some pipe beads and started the process, everything hose is silicone, I ran out of stainless so there’s that
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  20. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,339
    Dumpster Fire #31
    SMG
    If you're running a water based coolant, get a sacrificial anode for the tank. Run pentosin blue coolant.
    Looks good!
  21. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    If only I had a tank….. wink wink hint hint
  22. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,339
    Dumpster Fire #31
    SMG
    Need a new one?
  23. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    I have one from a GT4 that looks like it went thru a fire, I’ll test to see if it’ll work
  24. Jdubbya
    Jdubbya The $10 Trillion Man
    43,215
    PNW
  25. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,339
    Dumpster Fire #31
    SMG
