Outlaw 308 | Page 17 | FerrariChat
Outlaw 308
Discussion in '308/328' started by Vonbarron, Jul 20, 2019.
  1. ginoBBi512
    ginoBBi512 F1 Rookie
    3,535
    SO CAL
    GINO RUGGIERO
    I cant wait to see the finished product !! I know its going to be insane, I just thought I would throw that out there regarding the boost.
    Thank u, and hurry up !!! lol The waiting is killing us !! lol
    VAF84 likes this.
  2. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
  3. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    Absolutely amazing fabrication work you do!!
    I know you said you're doing straight pipes, but if you want, I have a beat up old euro Ansa exhaust you can have. Would give you a cat delete exhaust for starting and moving around without going deaf.
    I'm in West Seattle.
  4. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    Thanks for the offer Eric! I’m still monthsish away from fire in the hole. I’ve only been getting a few minutes a day working on it, going through the harness and remaking it all for lengths required for new layout, decided to go flux capacitor route. Made a new aluminum mount with flair, now cutting wires. I’m planning the absolute bare minimum of wires to run ignition, lights and fans. If I wasn’t so lazy I’d make adapters to run M5 Morris Magnetos and have no wires running the engine
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    NYC Fred and cavallo_nero like this.
  5. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    cavallo_nero likes this.
  6. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    Fast forward to July 4th, decided to try and fire the engine, cranked it for a few seconds at a time, zippo, kept trying. Zip. Put a spark indicator on number one plug and nothing, it was then that I noticed the oil flooding out the bottom of the filter mount, dammit. It was loose when I purchased the engine so I cranked it tight and tested, Exxon Valdez disaster happened again. Shut the lights off, closed the shop door and walked away. I had some time this morning before work to pull the housing and see what the hell. Color me stupid, there were three spring washers under the mount perfectly spacing it above the seal, my fault for not looking. Fixed that, cranked with no leaks. Still no spark but theres power to the coils, got out the XDI book and went thru all my wiring five or six more times before I put in the call to skunkworks (aka I forgot more than you’ll ever know, SMG2) quick diagnosis right over the phone and…. Figured out the crank sensor was not adjusted correct…. Anyway
  7. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    What? What’s that? Can’t hear you with the engine running so damn sweet
    yzee, Jdubbya, NYC Fred and 6 others like this.
  8. absostone
    absostone F1 World Champ
    10,036
    Yes!
  9. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,149
    SanFrancisco BayArea
    1983 US 308 GTS QV
    WOW! The monster breathes! CONGRATULATIONS. Super cool!!!
    samsaprunoff likes this.
  10. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,077
    Atlanta, GA
    Steve D.
    Kickass! Congrats!
    sjd
  11. Montblanc
    Montblanc Rookie
    Apr 8, 2012
    12
    Washington
    Rick
    I just binge read your thread... pretty awesome.
  12. Kingswood
    Kingswood Karting
    May 16, 2022
    148
    Stew
    My favourite thread.
  13. Jonny Law
    Jonny Law F1 Rookie
    3,203
    Over yonder.
    IT Guy
  14. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    The fuel tank is just in front of the wing, it’s a temporary stainless Empi unit until the Moon tank is built
  15. built2grind
    built2grind Formula Junior
    Oct 16, 2016
    419
    The Peninsula
    ANDREW
    It’s ALIVE!! Muahahahaha!
  16. Jonny Law
    Jonny Law F1 Rookie
    3,203
    Over yonder.
    IT Guy
    Ah, now that you mention it, I remember seeing it from the first post.
  17. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    746
    Omaha, NE area, US
    Steve
    Where did you source the blanking caps for the (former) distributor locations?
  18. ginoBBi512
    3,535
    SO CAL
    GINO RUGGIERO
    Oh my, Im getting a hard on !!! lol
    Thank you ,
  19. rob
    rob F1 Rookie
    May 22, 2002
    4,287
    Vt
    Friggin' sweeeeeeeeeeeeeeeeeeeeet even holds an idle
  20. built2grind
    Oct 16, 2016
    419
    The Peninsula
    ANDREW
    [emoji15]
  21. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    Time for a throttle cable, since it’s a carbed engine in a QV chassis, the cable is way to long, I don’t want to have one made or cut the cable and do a ferrule thingy. I just want an off the shelf part that works so the solution was to cut the welds on the pedal and reclock the arm until it works then reweld
  22. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
  23. NYC Fred
    NYC Fred F1 World Champ
    16,207
    Fort Lauderdale, FL
    Fred C
    Love the flying mirror!
  24. Jonny Law
    Jonny Law F1 Rookie
    3,203
    Over yonder.
    IT Guy
    When I re-wired the e-brake, I ended up using a lot of standing rigging from West Marine. The turnbuckles and Hi-MOD compression forks were ideal for dialing in the brake. Also ended up using a wire eye strap to reroute the cable away from the exhaust.
    NYC Fred likes this.
  25. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    absostone likes this.
