Outside door handle won't open UNLESS unlocking with key. | FerrariChat
Discussion in '360/430' started by DDavid, Jul 18, 2018.
  1. DDavid
    DDavid Karting
    May 3, 2018
    57
    DDD
    So, when I open the car using the fob, the passenger side works fine, but when I go to open the drivers door, the handle lifts up but nothing happens UNLESS I put the key in the lock and lock and then unlock manually. Then the door opens normally. This is on a 360 Spider. Any suggestions would be very much appreciated.
  2. deportm
    deportm Karting
    62
    El Paso, TX
    Anthony Figueroa
    A similar thing happened with my 360, except the opposite door. Turned out the cable connection from the outside door latch broke, which I found out was a semi-common issue. But Ferrari changed the cable housing assy, so I had to buy the new part, instead of just putting the old one back in place.
  3. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,197
    CA & DC
    +1
    Same as above. Had to buy a whole new lock mechanism
