outside door latch broke | FerrariChat
Discussion in '348/355' started by bigfatdadd, Nov 21, 2016.
  1. bigfatdadd
    bigfatdadd Rookie
    Apr 6, 2015
    15
    anyone have the door handle pop and then will not open the door ? any threads on this ? the door handle is in tack and still on the car something inside the door let go. i will be removing the door panel later this week but any help would be great. 1995 f355
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,549
    San Carlos, CA
    Mitchell Le
    The connection from the door handle to the door lock assembly is likely dislocated. Welcome to hell. You must have very small hands.
  3. Qavion
    Qavion F1 World Champ
    14,268
    Ian Riddell
  4. bigfatdadd
    bigfatdadd Rookie
    Apr 6, 2015
    15
    the inside works fine just the outside not
  5. Ricambi America
    Sponsor Owner
  6. Qavion
    14,268
    Ian Riddell
  7. Turbo Ron
    Turbo Ron Formula Junior
    Nov 3, 2003
    262
    West Los Angeles, CA
    Ron Stavis
    I had that happen to mine, and the Ferrari Dealer removed the outside panel to do the repair. Not from the inside door panel. Much easier to get to as I remember. No longer own the car.
  8. Qavion
    14,268
    Ian Riddell
  9. yelcab
    Nov 29, 2001
    13,549
    San Carlos, CA
    Mitchell Le
    The picture showing a plastic arm is where the outside handle attaches to the lock. It is in an awkward place where you cannot squeeze the rod end into the plastic hole. I just had to do this a few weeks ago and I ended up ...
    Removing the outside door panel
    Removing the inside door panel
    Remove the lock from the door so I can connect first the door lock to the outside door latch
    Then, put the door lock back on and connect everything else
    Good luck man.
