Outside Mirror Adjustment | FerrariChat
Discussion in '308/328' started by offtheworkigo, May 5, 2016.
  1. offtheworkigo
    offtheworkigo Karting
    Feb 23, 2016
    237
    Rockwall
    Dave Hoffer
    Is there a adjustment on my right side outside mirror on my 85 308 euro. I have electric mirrors which work, but can I change the position of the mirror housing itself? Even adjusting the mirror glass tilt all the way down, the mirror is not down far enough to see good. I'm looing at to much sky and not enough of the road.
  2. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,220
    Gold Coast, Aust.
    Patrick
    There's a ratchet type mount - just push it with your fingers and it will click down
  3. offtheworkigo
    Feb 23, 2016
    237
    Rockwall
    Dave Hoffer
    Thanks for answering. I went out to the car and grabbed the whole mirror and tried twisting it down to the point I though sometime might break. Is that what you meant me to do?
  4. offtheworkigo
    Feb 23, 2016
    237
    Rockwall
    Dave Hoffer
    I may not be explaining my self right. The mirror housing will move up and down, forward and back. But mine needs to be like twisted. Looking down, the top on the mirror is not at a 90 degree angle with the ground. Its like a 110 degrees tilled back.
  5. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    '84 euro here. If you pull back the accordian rubber piece, there's at least one adjustment screw in there. Not sure if that will help at all.
    Once pulled away, getting the rubber accordian piece to reseal in the plastic mounting bracket (there's a groove there) takes a little fiddling though.
  6. Ferraridoc
    Jun 20, 2012
    17,220
    Gold Coast, Aust.
    Patrick
    Not the whole mirror housing, just the mirror glass itself.
  7. offtheworkigo
    Feb 23, 2016
    237
    Rockwall
    Dave Hoffer
    Thanks. After looking closely at the left side the right side is not mounted on the door square. I think I need to loosen the mirror assy and see if will mount square on the door and that will fix the adjustment. To loosen the mirror from the door do I need to take the door panel off to the get to a nut or screw?
