Overcharged Battery in 355?? | FerrariChat
Discussion in 'Technical Q&A' started by Lazy Ace, Sep 6, 2010.
  1. Lazy Ace
    Lazy Ace Rookie
    Feb 20, 2007
    41
    Cody, Wyoming
    Bob Ferguson
    I think I may have overcharged my battery but not sure what the symptoms are or any possible damage that might have ocurred. I left it hooked up to my Schumacher battery charger for about 6 weeks without driving. I'm pretty sure it was on the 2 amp/12 volt charge setting. When I got back, the charger was hot and there was very little charge. The door locks would barely work and starter wouldn't turn over or even click. Upon trying to start the car, the brake and parking lights started flashing very fast (faster than hazard mode.) How do I know if it was over charged and is there any way to correct it without replacing the battery?
  2. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    I ruined my battery with a Schumacher trickle charger, and now I buy the brand "Battery Tender".
    I think you may be on the right track in thinking that you need a new battery.
    JM
  3. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Symptoms of overcharged battery are low electrolyte. You may have boiled the water out of the battery. If you wish to rejuvenate the battery buy a gallon of distilled water in your grocery store. Make certain it is truely distilled and not just fancy drinking water. Remove the battery from the car. Use safety glasses - MANDATORY from here on.
    Pop off the covers at the top of each cell and fill each of the six cells with distilled water almost to the top. There are often marks or molded in features to indicate full. A small funnel and flashlight are often quite helpful.
    Charge the battery slowly leaving the cell covers OFF. Slow because the acid and water need to mix and a fast charge excites violent liquid motion which can damage the plates. And covers OFF because if things aren't going well, fumes can build up and expel or squirt some acid. You still have safety glasses on don't you?
    Most times the battery will be ok, depends. Dendrites or slivers of lead extend from the plates of well used batteries and can drop to the bottom when the water level gets low and short out a cell. After charging, cell caps on and reinstall.
    I would buy a new battery but in an emergency situation, the refill-rejuvenate-recharge does work in cases where the battery was fine before the overcharging occurred.
  4. f355spider
    f355spider F1 World Champ
    18,047
    I have attempted Paul's suggestion before...while it did restore some function to the batteries, I have found they had very little capacity left. I connected up a load tester and typically found less than half their rated capacity. Generally, once you have boiled out the electrolyte, you might as well replace the battery...YMMV.
