Overheat Light Won't Go Out? | FerrariChat
Discussion in 'Technical Q&A' started by UroTrash, Jul 18, 2011.
  1. UroTrash
    Jan 20, 2004
    40,691
    Purgatory
    Clifford Gunboat
    #1 UroTrash, Jul 18, 2011
    I just bought a 1975 BMW 2002 fixer upper to work on with my daughter.
    Work's progressing nicely, but I have one minor problem I can't figure.
    The car had been running fine for about 500 miles or so over the last week, but suddenly, Thursday night it overheated.
    The radiator water was full and tepid, so I figure a stuck thermostat, bad water pump or something like that. Haven't cracked it open yet. Engine oil clean, not cloudy, not foamy.
    That's not the question.
    The question is the overheat idiot-light came on and even thought the car is stone cold now, the light stays on.
    I'm thinking a bad sending unit?
    Any ideas appreciated!
  2. GuyIncognito
    GuyIncognito Ten Time F1 World Champ
    100,320
    no clue, but on the bright side now y'all have something to fix up! :)
  3. UroTrash
    Jan 20, 2004
    40,691
    Purgatory
    Clifford Gunboat
    Tru dat.
  4. GuyIncognito
    100,320
    hey Dean, you got some cool cars....an old Fiat, two sweet BMW's, your wife's CLK.
    why don't you put those in your "garage" instead of all those crappy Caravans?
    :p
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #5 2NA, Jul 18, 2011
    Looks that way to me. There might not be anything wrong with the cooling system.
    Get one of these (pretty cheap these days) and you will know for sure.
  6. UroTrash
    Jan 20, 2004
    40,691
    Purgatory
    Clifford Gunboat
    I think that would be great to have. Use it on the grill and smoker too!
    I guess, I left out an important part, there is a temp gauge as well as an idiot light.
    The temp gauge seems to function fine and rapidly rises into the red zone. as the engine runs.
  7. UroTrash
    Jan 20, 2004
    40,691
    Purgatory
    Clifford Gunboat
    fiat......
  8. GuyIncognito
    100,320
    almost? ;)
  9. UroTrash
    Jan 20, 2004
    40,691
    Purgatory
    Clifford Gunboat
    On a positive note, the CLK is growing on me, it's what we usually take when we go out; what a nice car.
  10. dm_n_stuff
    Dec 10, 2003
    43,879
    26.806311,-81.755805
    Dave M.
    Sounds like a stuck thermostat.
    Take it out, close 'er up and start it.
    If it doesn't overheat, we fixed it. Get a new thermostat at your leisure.
    If it does overheat, next stop is the water pump.
    Hell, this should be easy for you, I thought plumbing was your specialty. :D
    D
  11. dm_n_stuff
    Dec 10, 2003
    43,879
    Dave M.
    Oh, and just pull the plug on the back of the idiot light, that'll take care of that little issue too. Never have to worry about it coming on again and cluttering up your dash with a pesky warning.
    D
  12. UroTrash
    Jan 20, 2004
    40,691
    Purgatory
    Clifford Gunboat
    Sayyyy.... I wonder why the Dino lights never.....
  13. dm_n_stuff
    Dec 10, 2003
    43,879
    Dave M.
    #13 dm_n_stuff, Jul 18, 2011
    well duh.
    I got really annoyed by those brake warning lights. and the one that tells you in the alternator is working, and DAMN, that overheat warning came on ALL THE TIME.
    It really pissed me off, so I pulled the fuses for all that stuff.
    You might be able to find them floating around in the trunk, under the carpet if you look real hard. They'll be right next to the backup ignition stuff for the Dinoplex, that I disconnected. :D
    DM
  14. UroTrash
    Jan 20, 2004
    40,691
    Purgatory
    Clifford Gunboat
    Don't know about that stuff but I did put a permanent Battery Tender drop in last night.
  15. dm_n_stuff
    Dec 10, 2003
    43,879
    Dave M.
    #15 dm_n_stuff, Jul 18, 2011
    Shouldn't really need that. Nothing in the car to drain the battery, what with all the electrical stuff disconnected. :D
    you'd be better off installing one of these. :D :D
    DM
  16. UroTrash
    Jan 20, 2004
    40,691
    Purgatory
    Clifford Gunboat
    HA! The Original South Carolina Battery Tender!
  17. mpodgor
    mpodgor Formula Junior
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    As old as the car is I suspect the light is actuated by a temp switch. Which is a simple Bi-metalic switch that closes at a specific temp. Sounds like it closed and stayed that way. It should be a 2 wire sensor that is connected in the cooling system somewhere. 1 wire if it uses chassis ground. You really need a wiring diagram or schematic of the car. But if the light is on when the motor is cold that would be it I'm sure. Good luck. Probably should look for a BMW forum.
  18. Ehamilton
    Ehamilton F1 Rookie
    2,759
    Durham, NC; USA
    Eric Hamilton
    yep, that's an important part :)
    You can ignore the annoyance of the light being stuck on (it'll be some dorky electrical problem, you'll have twenty more before you've finished sorting the car) until you've fixed this very real and potentially engine-killing overheating problem.
