Overheat? | FerrariChat
Overheat?
Discussion in '308/328' started by kcabpilot, Oct 28, 2017.
  1. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    California SF bay area
    Paul
    Yesterday while stuck in traffic my temp gauge rose rather rapidly to around a needle width past the tick mark between 195 and 250 so let's say maybe 230 indicated. When I started moving it rapidly dropped to just a touch over the 195 mark. When I got home and let it idle in the garage I was checking to make sure both my fans were running and they were but after about a minute they shut off despite the fact that my indicator was now reading about 220 or 225.
    Has anyone else ever experienced this? Is it possible I have a bad thermostat?
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
    The fans turn on via a thermal switch on the rad while the gauge gets its reading from a sensor on the engine. First step would be to make sure your system is properly bled as an air pocket can cause what you are experiencing.
    To bleed the system park the car on an uphill grade so that the top of the rad is as high as possible. Then have the car up to temperature and idling. Make sure the heater is also set to full hot (important to avoid big air pockets). With the car idling open the thumb screw on the drivers right top of the radiator. Turn it a few turns and close it once you get a steady stream of coolant without any air in it. Be sure to wear gloves and have some rags handy. The whole procedure should take a few minutes and might need repeating with a drive in between to circulate things.
    If your problem persists after this you may want to start looking at the sensors for the rad fans and the dash gauge. For now just try the bleed.
  3. JohnnyTS
    JohnnyTS Formula Junior
    Jun 3, 2012
    907
    Pretoria East, RSA
    It sound more or less what most tell me of their 308's, they run a little hot in traffic and the temperature will drop when moving on the road, especially cruising at at 70/75 miles per hour - with the gauge settle around 195 or just below, your fans could be kicking out to quickly when idling in traffic not sure, if the thermostat got stuck the gauge will move to the far right past 250/280 and you would have noted more heat.
    a good radiator flush with new coolant could help a little, when last did you replace this ?
  4. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
    When I bought my 308 15 years ago I immediately re-cored the rad and had the coolant changed. In all my years of driving I have NEVER had the temperature creep up (except for one time that was bleed related). I have been in the hottest and most humid weather you can imagine in absolute bumper to bumper traffic with zero air flow to the rad for well over an hour and the engine never ran hot. To me traffic related over heating is either air in the system or a partially blocked radiator. These cars have extremely narrow passages in the rad that cannot be effectively `boiled out`by a rad shop. The only solution is a new core and it is important to use a core that is of the same density as the OEM one. Most shops fit cores with larger and fewer passages and these rads never seem to cool well. Ferrari actually got their cooling system right and overheating cars are usually down to poor maintenance or parts over the years.
  5. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,150
    SanFrancisco BayArea
    1983 US 308 GTS QV
    I wonder if it is a wonky fan switch?
    Very few people make THAT claim!
    Personally, I think it is an airflow issue. The fans don't push enough. People consistently report that once their cars get moving, things cool down. This suggests to me that it is not a radiator flow problem.
  6. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    Paul
    Went to Harbor Freight and bought an IR thermometer gun. I did recently drain and refill my cooling system. I filled it with both bleed screws removed (radiator and water pump) until I had flow out of both. I did not, however, have the heater valves open. So I'm going to re-bleed the whole thing and do some tests with the IR gun today and see what I can come up with.The first thing I noticed is that it definitely got hot because I'm way down on coolant level and it's all over the left side of the sway bar where the overflow hose is. Is there a DIY way to test my pressure cap?
  7. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    Paul
    Correction: second bleed screw on thermostat housing, not waterpump.
    Also, unscientific method of checking cap - I pressed down on it while on a scale and it seemed to move at around 16 lbs.
  8. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    628
    Massachusetts
    Joe
    +1
    I also have a two valve version of the 308 and it does not overheat.
    If you have not had your radiator checked in over 30 years, it's now time.
    If you do not open up your heater control valve, you are not totally filling up your cooling system.
    If it has been 30 years plus since you checked the fans, temperature sensors, hoses, thermostat and water pump, it's now time.
    If you do not have 4 pieces of foam rubber around your radiator, you are losing efficiency.
    Some air is going around your radiator, not through it. Foam rubber should be on all four sides of the radiator. A large foam rubber piece is glued under the hood and rests on top of the radiator when the hood is closed. There are foam pieces on each side of the radiator and a piece of foam under the bottom of the radiator that rests against the bottom of the radiator and the front valence. These four pieces make a BIG difference. (An additional piece of foam rubber is further back and glued to the underside of the hood and rests on top of the spare tire carrier, this helps keep some of the hot air from the front compartment from going through the fire wall and into the cabin, which makes it hot. Also, if the four previously mentioned pieces are missing, you will have more heat going into the cabin.)
    Don't blame the car, blame deferred maintenance.
    Nuvolari likes this.
  9. kerrari
    kerrari Two Time F1 World Champ
    Oct 22, 2004
    24,044
    Coolum Beach AUSTRALIA
    Karen H.
    only time I've ever had an overheating prob was due to failed thermostat. it was 10 years old.
  10. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    Paul
    I'm thinking that if my thermostat failed moving down the road wouldn't have helped. I just re-topped the tank, a lot of air came out of the radiator bleed. I'm going to run it later with heater valves open, let it get up to temp, see when the fans come on and see what kind of readings I get with the IR gun. I think one of the guys in our group just did his radiator and it solved a similar problem so I'm not ruling out having to go that route in the end. I'm not a stickler for originality so if anyone has suggestions for a good after market radiator I'm all ears. I know Nick Forza sells one but they're like eleven hundred bucks.
  11. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    Paul
    #11 kcabpilot, Oct 28, 2017
    Test results: After topping off and re-bleeding - and I should say first off that I had to add nearly half a gallon of coolant - I let the car idle in the garage for about fifteen minutes. The instrument gauge remained centered at the 195 tick. The fans turned on when the IR gun read 188 on the radiator header. The coolant tank gave the same reading as the radiator. What I did notice however was a constant stream of coolant coming out the overflow tube.
    So my conclusion at this point is that I have a bad pressure cap and I have simply been loosing coolant. So, is this a standard 1.1 Bar cap or do I have to get it from somewhere "special"?
    Okay never mind I did a quick search and ordered a Stant 10231 on Amazon for five bucks.
  12. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,877
    Mike 996
    A constant flow of coolant from the overflow tube? The first thing that causes that is an over-full system - IOW, when cold there is too much coolant in the tank and as soon as the engine starts warming up a bit and the coolant volume increases, it exceeds the pressure of the spring and begins overflowing. BUT, it will quit after the engine establishes the "correct" level. It will do that on its own, spitting from the overflow hose. So are you saying the constant overflow occurs regardless of engine temp or once the engine is up to operating temp?
    If it occurs at operating temp, as you noted, a bad Rad cap can cause this but again, only after the pressure/volume come up. If the pressure spring is weak, it may allow the coolant to boil near the normal boiling point of water as opposed to 230-240F of a properly pressurized system. If the coolant boils, it will, blow coolant /steam from the overflow. The cap's spring pressure has no direct affect on the coolant's volume increase as temp goes up. The coolant volume increases based on temp, not pressure. The pressure cap/pressure in the system simply raises the boiling point of the coolant.
    As noted, the problem might be air in the system and bleeding should correct that. But if there is a need for repeated bleeding, there is a leak in the system somewhere. The system can be bled per the instructions in the owners manual, and it will stay "bled" until the next time the coolant is changed or until there is a leak somewhere. A leak may not be a visible stream/puddle/seep. There may be no readily visible sign. A pressure test is the best way to find a leak if you find that periodic bleeding is needed and there is no visible leakage.
    Of course, there are other, more serious issues that can cause a need for repeated bleeding, loss of coolant, or erratic temperature gauge readings. But usually it is just a simple issue of rad cap problem or minor leak somewhere.
  13. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    Paul
    Thanks Mike I understand all of that and this five dollar cap is the first step. If I'm lucky that will be the end of it but I'm not counting my cows until they all come home. I did fill the tank up to the spec level about three inches below the neck so we'll see what happens with the new cap.
  14. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    Paul
    Update: Installed the new cap and let the car idle for 25 minutes in the garage. The temp was stable at 195 on the gauge, IR gun reading was 193 on both radiator and expansion tank. The fans turned on at 185. No coolant coming out of the overflow tube other than a few drops as it reached operating temp. So it sure looks like I found the culprit, a five dollar fix on a Ferrari can you imagine that? But I'll admit being a bit concerned because if you were to just look at the old cap there is nothing visible that would clue you into it having a problem. It looks just fine. Even the spring feels normal, wish I could figure out a way to do an actual test on it.
  15. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    The beginning of my coolant problems started with an old cap + overheating + gushing out the overflow tube. After I replaced the cap, I thought my problems were solved... but over the next few days, I started noticing a leak elsewhere which took quite awhile to track down and repair. I've wondered if replacing the cap led to older components now being at more pressure than they could deal with (due to their age).
    So - keep an eye on your coolant level, and the garage floor for the next few weeks. Hopefully you're done with the issue completely. :)
  16. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,877
    Mike 996
    "It looks just fine. Even the spring feels normal, wish I could figure out a way to do an actual test on it."
    In the old days, every gas station did repair work and had a tester that could check Rad caps. Whether anybody has one now...well, probably not! :(
    As Thorn suggested, keep an eye on things initially with the new cap and probably a bit higher system pressure. Check how the temp reacts in normal driving while out on the road.
  17. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    And keep a full bottle of coolant in the trunk.
  18. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    Paul
    I’ll definitely keep an eye on things. After the system had cooled I opened the bleed screw on the radiator and there was air but this seems to be a common thing, not sure if it’s really an issue or if anything can be done about it, seems to be a “feature” of the design.
  19. George Vosburgh
    George Vosburgh F1 Rookie
    I would like to point out that on any North American 308 with the big fat bumper on the front the bumper is deflecting the air away from where it was designed to go. If you change the front bumper to a "European Style" bumper, which is the bumper designed for the car, you will not experience overheating under normal driving conditions.
    I promise!
  20. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    It can take 3-5 sessions (repeated bleeding) to get all the air from the radiator and the engine. But once bled, it should stay quite bled. If not, you have air leaking in from elsewhere.
  21. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    Paul
    Hmmm, not sure about that theory. For one thing, prior to my issue with the cap I never had any overheating symptoms and when I did it was only when stopped in traffic and relying on the fans, temps were still normal while I was moving. I'm not defending the weight or sheer mass of the US bumper but I don't think it has much effect on cooling. In my particular case the bad cap caused a loss of coolant. When the cap was good and holding pressure the system worked fine in all driving conditions including being stuck in traffic.
  22. ClydeM
    ClydeM F1 World Champ
    11,954
    Wayne, NJ
    Clyde E. McMurdy
    Lots of threads here on overheating & assorted fixes.
    My '83 consistently gets very hot in heavy, slow traffic. I dread stop & go and parking lot traffic. Forget the A/C when the car isn't moving. Start driving, the temps drop.
    I've gone most of the whole route of rad cleaning, hose replacing, radiator foam. Nada. A buddy went further with Nick's radiator & new fans. Nada.
    Someone on here was offering an autobleed kit with Euro hot-water bleed caps for the radiator & engine gooseneck. I installed them and they are great. No more bleeder screw rubber gaskets becoming brittle with age & heat cycling. No more scalding coolant spitting out with the air. No more constant bleeding. But if I'm sitting in traffic, the temps still rise into the 230 zone.
  23. jmaienza
    Jan 8, 2009
    628
    Massachusetts
    Joe
    My 78 308 with the big fat bumper does not overheat, even in stop and go traffic. The air goes under the big fat bumper and into the grill. As ugly as the big fat bumper is, I have no intention of changing it.
    With all due respect, I think when you make such a generalization that "on any North American 308 with the big fat bumper...you will experience overheating under normal driving conditions." is quite silly. So, with the big fat bumper under what conditions will it not overheat...only by removing it?
    I have confidence that when the Ferrari engineers designed the big fat bumper they certainly were not planning on having it overheat their engines. Please give them some credit. Ferrari does tend to take pride in their engines!
  24. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
    Also My North American QV with the big fat bumper never overheated even driving in LA rush hour traffic during summer and I still have the stock radiator and stock water pump in eleven years of owning it. So I don’t know what the heck George is talking about.
  25. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,877
    Mike 996
    "No more constant bleeding."
    If bleeding is constantly required, there is a leak in the system. Once bled, it is bled until you drain/replace the coolant. When these cars were new, owners weren't taking them to the dealer every couple of weeks to have the coolant systems bled. ;)
