overheating after flush | FerrariChat
Discussion in '308/328' started by tatcat, Jul 7, 2006.
  1. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    recently had my 85qv power flushed. no problem prior but been running hot ever since. have tried bleeding rad several times to no avail. thinking debris has affected thermosat. will try bleeding engine next. what is entailed in replacing therm. have seached but not much on the actual process. has anyone used the vw part recommended in the parts sticky. read an old post about a chevy part, sounds fishy. haven't actually measured the coolant temp. will check that next.
  2. Jdubbya
    Jdubbya The $10 Trillion Man
    42,816
    PNW
    The thermostat could be causing the problem but I kind of doubt it. I think the VW part in the other thread your talking about is actually the switch in the radiator that turns the fans on. Have you checked to make sure the fans are turning on? If so the first thing I'd do is properly bleed the whole system (not just the radiator). See Verell's excellent explanation here... http://ferrarichat.com/forum/showpost.php?p=135067366&postcount=25
    If that doesn't solve it then start looking at other sources.
  3. PAP 348
    Dec 10, 2005
    100,208
    Mount Isa, Australia
    Pap
    Just going by what you have mentioned. I have power flushed many times before and sometimes, old block casting/rust can break free and get stuck in the thermostat. This can cause the thermostat to be stuck open and cause overheating. So check the thermostat for sure. Maybe you just have a nasty airlock in the engine block? Have had that before also. Good luck mate. :)
  4. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    You have to bleed it at both ends (engine and radiator) or it will run hot.
    Birdman
  5. Dr Tommy Cosgrove
    36,329
    Birmingham, AL
    Tommy
    You should still buy the "performance" VW fan switch. It just turns the fans on a little earlier.
  6. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    Rick...super easy job. Call Ricambi and tell him you need a new thermostat (comes with o-ring gasket IIRC) and you'll also need a new thermostat housing gasket. You'll want to completely drain your whole system (rad and engine) and start from scratch.
    Call me if you have any questions...
  7. NYCFERRARIS
    NYCFERRARIS Formula 3
    Mar 2, 2004
    1,011
    there is a bleed screw on the rad and also on the thermo housing...
  8. stevej33
    stevej33 Karting
    Feb 16, 2004
    76
    Lincoln, UK
    Steve Jollands
    hi there,
    not been on here in a while...
    Ive had a similar problem with my QV engined Mondial, im i right in thinking if the thermostat is stuck closed, the water won't flow to the rad?? hence the engine will get hotter and hotter until something goes bang??
    thanks
    Steve J
  9. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Yes, but this is pretty uncommon. They tend to stick open. If it is stuck shut, the radiator should not get hot, so it is very easy to test.
    Birdman
