Overheating Oil Temp 2000 360 Help please | FerrariChat
Discussion in 'Technical Q&A' started by alexkam, Mar 14, 2007.
  1. alexkam
    alexkam Formula 3
    Mar 14, 2007
    1,116
    Sunny CA
    Alex
    Hi, Im a new owner of my first Ferrari 360, year 2000. I was doing alot of city driving the other day and noticed my oil temp in the red, it was going in and out of the red for a few minutes, the engine temp was fine and the oil pressure was also fine. After letting the car cool down for about 15 minutes I drove it a few miles and then the oil temp was fine. Should I be concerned? Spoked me out a little, but overall the car runs great and their was no signs of smoke or overheating. I appreciate any input. Thanks! Alex
  2. Rifledriver
    37,274
    Anytime any instrument or monitoring system is in the red it is cause for concern.
    A professional pilot once told me "When an instrument tells me something is wrong I know it is probably a faulty reading. To not believe the instrument and not act accordingly is stupid".
  3. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    You would get better response if you filled out your profile.
  4. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    On lots of cars an oil temp sensor shorting to ground will pin hot on the gauge. Nevertheless, if you can afford a 360 I hope you can afford your local Ferrari mechanic to diagnose if it's a sensor or if you're frying your engine. I question how much on a 360 is a DIY thing unless you see an obvious cause: burnt wires shorting on a ground, etc. You most likely need a Ferrari mechanic to be safe.
    Ken
  5. alexkam
    alexkam Formula 3
    Mar 14, 2007
    1,116
    Sunny CA
    Alex
    Thanks Ken!
  6. alexkam
    alexkam Formula 3
    Mar 14, 2007
    1,116
    Sunny CA
    Alex
    Good Words Of Wisdom!
  7. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    Might sound like a stupid question but have you checked the engine oil level? and welcome to FChat ;)
  8. fatbillybob
    Aug 10, 2002
    29,189
    socal
    Unless the instruments are Italian! Then if you get confimration that other instruments like engine coolant temp show normal then use caution but suspect the oil temp sending unit. Welcome to italian electronics
  9. alexkam
    alexkam Formula 3
    Mar 14, 2007
    1,116
    Sunny CA
    Alex
    Probably a real stupid answer, but no i haven't. Doing so now. Thanks!!!
  10. PAP 348
    Dec 10, 2005
    100,224
    Pap
    ;) The amount of oil is not only there for lubrication but also serves other purposes such as cooling,ect... :)
  11. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,825
    Cerritos, CA.
    What goods are the guages, warning red light, buzzer, or any types of monitoring device if you don't respect and ignor them, they are there for reasons very important reasons.
  12. alexkam
    alexkam Formula 3
    Mar 14, 2007
    1,116
    Sunny CA
    Alex
    Thank you all for the input. Much appreciated!
  13. Rifledriver
    37,274
    If you quit having such contempt for Italian electronics you might find they can work quite well. And if you have such contempt for it why do you own them? We have a late model Benz and it is absolute garbage. Ferrari electronics were far superior in every way before they started buying German garbage. I have some experience with German cars and I will never have another. If I could opt out of the German crap in Ferrari I would do that as well.
  14. fatbillybob
    Aug 10, 2002
    29,189
    socal
    LOL! Brian...the reason is because WE are the truely devoted. You work on these cars all day then come post on Fchat. I'm either posting here or working on my Ferraris. Now it is pretty obvious that both of us have taken this hobby to extremes. If you just wanted to fix cars and get a paycheck you would have worked for Toyota but instead you chose Ferraris. Maybe both of should see a shrink.
  15. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Back in the day, we threw off the Lucas systems for Magnetti Marelli in F1, they were more reliable (hard to imagine that eh?). But the problem with any of these things is that people condemn them without a total understanding of function, therefore ability to diagnose. As Brian says, don't blame the product for your ignorance.
  16. fatbillybob
    Aug 10, 2002
    29,189
    socal
    I do not know who you are but perhaps you should do a search on my name and read a few of my posts before you show "your" ignorance.
  17. 308 milano
    308 milano F1 Veteran
    5,342
    Montana
    Kim
    Brian S Dude, That was totally uncalled for!!
  18. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    maybe a silly question- but if the oil gauge is reading extremely hot, wouldnt the water/antifreeze gauge reading hot as well ?
  19. Rifledriver
    37,274
    Sometimes yes....Sometimes no
  20. 308 milano
    5,342
    Montana
    Kim
    BrianS I have only been a member of Ferrari chat for a few months but Im constantly amazed at the length some people will go to inch their nose up rifledrivers rear
  21. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    One would assume that, yes. That's why I suggested the gauge/sender might be shorting to ground. If the whole engine was overheating, I assumed the initial post would have been worded differently, like, "My car is overheating!" as opposed to the oil temp only. He even said the car was NOT overheating.
    Ken
  22. Rifledriver
    37,274
    I know Brian. It's all OK.
    I think it's just a matter of interpretation.
  23. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    That's the problem with Limeys. It was never intended as a slight to anyone particular just a generalisation. It gets old reading the same reposts/whining, I'm just very grateful to be able to gleen some useful info from this site.
    Now, go have a good day!
  24. Rifledriver
    37,274
    I'm half Limey and half Kraut. I'm really AFU.
  25. ZINGARA 250GTL
    ZINGARA 250GTL F1 World Champ
    Jun 21, 2002
    17,499
    PA
    Ken
    Rifledriver seems anything but AFU. Me, I'm pure WOP (without papers), guinea, and dago. Granson of a 1905 Italian immigrant who went through Ellis Island; learned english with a newspaper and a dictionary (which he memorized) So what! What I am is an american. I am not a honky, however.
    Limey merely refers to British sailors of the late 18th and early 19th centuries, who drank lime juice to prevent scurvy. Hence, the term. Sorry for being tedious.
